Thread: V6.51.sp0.build0 runtime error
    Default V6.51.sp0.build0 runtime error
    Hello ,
    I have a zenon working application for years and now after minor modifications after starting the runtime i have the following error
    any hints?
    OS winxp
    Best Regards
    Ziad
    Hello ,
    any hints?
    OS winxp
    Best Regards
    Ziad
    Default Re: V6.51.sp0.build0 runtime error
    Hello Ziad,
    You can try and rename the runtime data folder (this folder has the name of the PC and by default is in the same folder as the RT folder containing the runtime files) and see if this works. (Assuming you don't have backups to which you could revert)
    ok just solved it in case anyone faced the same issue
    create a backup of the project , deleted the old project folder and Created and  restored as new
    now everything works
    Best Regards
    Ziad
  1. Replies: 2
    Last Post: 19th May 2018, 06:19
  2. Runtime Error
    By sidramsatyal in forum zenon Supervisor
    Last Post: 21st November 2013, 13:40
  3. Runtime error
    By ansab.tp in forum zenon Supervisor
    Last Post: 30th January 2013, 11:11
  4. Runtime Error
    By shikra in forum zenon Energy Edition
    Last Post: 10th April 2011, 16:25
  5. Projekt von Zenon 6.20 SP4 Build5 nach 6.22 SP1 Build0
    By xxx in forum Editor and Runtime Setup
    Last Post: 2nd June 2009, 10:33
