Thread: Where can I find ZenOn PC Runtime V5.5 SP7?
    20.02.2019
    3
    Default Where can I find ZenOn PC Runtime V5.5 SP7?
    Hello everyone!
    I can't download Zenon software from downloads section.
    I only need the installer of ZenOn PC Runtime Version 5.50 SP7, to install in another PC because the PC where was installed it, damaged, and I need to migrate the proyect to another PC in order tu Run the machine again.
    I don't need to edit, I only need the Runtime version to run the application into another PC. The machine is Stopped and the customer is urged to start up his machine
    Could you help me please!
    Thanks a lot in advance
    28.02.2013
    170
    Default Re: Where can I find ZenOn PC Runtime V5.5 SP7?
    Hello MarianiSalguero,
    version 5.50 is quite old and out of our product and support lifecycle. So therfore there is no download on your website.
    Please contact your local COPA-DATA representative to clarify your options here.
    Felix
    20.02.2019
    3
    Thanks Felix!
    Please, could you indicate me who is COPA-DATA representative into Venezuela?
    In addition, An application made with ZenOn v5.50, is compatible with the new ZenOn version?
    What I would have to make in order to run the old application into a new version of ZenOn?
    Thanks a lot for your prompt response!
    28.02.2013
    170
    Lächeln Re: Where can I find ZenOn PC Runtime V5.5 SP7?
    Hola MarianiSalguero,
    please contact sales@copadata.com and include as much information as possible to enable a fast and clear answer.
    What is the project all about, license number, etc.
    Felix
  1. Find Maximum or Minimum Value
    By arshad30ali in forum straton / zenon Logic
    Last Post: 17th January 2018, 10:02
  2. Replies: 3
    Last Post: 18th May 2016, 09:37
  3. How variable get or find COA and IOA
    By aleks2 in forum VBA
    Last Post: 18th July 2013, 12:43
  4. CE doesn't find runtime-server
    Last Post: 28th August 2007, 11:44
