Thread: Cleanup Setup Instructions
    02.05.2017
    31
    Default Cleanup Setup Instructions
    This is a tutorial on how to properly clean up a zenon installation. Replace the '760' in the paths by the actual version number.
    1. Run the CleanupSetupXXX.exe and clean the registry with the tool. The tool removes all setup information and Editor Profiles from current user.
      If there are several users working on the same PC you have to run the tool for each user.
    1. Completely delete the following folders:
      1. %ProgramData%\COPA-DATA\zenon760
      2. %LocalAppData%\COPA-DATA\zenon\Editor
    1. End the following services:
      1. zenadminsrv
      2. zenlogsrv
      64 bit operating system:
      1. %CommonProgramFiles%\COPA-DATA
      2. %CommonProgramFiles(x86)%\COPA-DATA
      3. %ProgramFiles%\COPA-DATA\zenon 7.60 SP0
        (or your userdefined installation folder)
      4. %ProgramFiles(x86)%\COPA-DATA\zenon 7.60 SP0
    32 bit operating system:
    2. %ProgramFiles%\COPA-DATA\zenon 7.60 SP0
    1. Uninstall the zenon web server and zenon web client where applicable.
    09.08.2017
    10
    Default Re: Cleanup Setup Instructions
    Thank Lukas,
    where can I find the reg cleaner?
    02.05.2017
    31
    Default AW: Cleanup Setup Instructions
    Hello James,
    you need to contact your local zenon support in order to request the Cleanup Tool for a specific version. These tools are not available directly on our website
    Best Regards
    Lukas
    05.10.2019
    Well i was in searching for this information and finally i got this information here on this forum thanks for this have a nice day friends
    08.11.2019
    7
    Thanks! this is helpful. I run this method and it helped!
    Lewis
  1. Integrate/Connect/Link HMI graphic with PLC instructions
    By afz2004 in forum straton / zenon Logic
    Last Post: 9th October 2018, 10:18
  2. Screen setup runtime
    By rizwanwar in forum zenon Supervisor
    Last Post: 7th March 2016, 09:02
  3. Zenon CE detailed installation instructions
    By rjclayton in forum zenon Operator
    Last Post: 6th February 2012, 09:49
  4. Setup a filter at design time
    By matholton in forum zenon Supervisor
    Last Post: 3rd October 2008, 08:40
  5. WibuKey setup on 64 Bit Windows systems
    By juergen_fruehwirth in forum Editor and Runtime Setup
    Last Post: 19th September 2007, 15:05
