Thread: Get a variable value
    nblanquart Gast
    Default Get a variable value
    I would like to get the value of a variable, but ZenOn throws me an "Undefined" error.
    That is the code I implemented at this moment.
    Dim Temp As variable
    Temp = thisProject.Variables.Item("time_temp").Value()
    Thanks for helping.
    28.07.2008
    64
    Default Re: Get a variable value
    This should be work. Be sure that your string is correct-> case sencetive!
    880
    check out this thread regarding reading of variable values via VBA:
    http://www.copadata.com/forums/showp...2&postcount=12
    nblanquart Gast
    Thanks for your answers
    nblanquart Gast
    Okay.. So I have an other problem. I try to put a value in a variable but it always shows me a "0" in the ZenOn Runtime.
    That's my code:
    Sub archiveSetTime()
        thisProject.Variables.Item("test_archive_timer").Value = Now
    880
    The Now() functions returns the current date/time in form of the data type Variant (Date)
    -> which datatype does the variable "test_archive_timer" have?
    Declare your variable as String and it should work then.
    Note: there exists also a zenon function which writes the current date/time to a variable
    -> see function at the category "Variable" -> Write time to variable
    "With this function a connected PLC can be synchronized with the PC. When executing this function, the System time is taken and saved in a String varialbe of the format: DD.MM.YYYY HH:MM:SS"
