Thread: IEC 60870-5-101_104 Value Write Issue
    Default IEC 60870-5-101_104 Value Write Issue
    Dear Support Team,
    We are set an setup of IEC 60870-5-104 Straton as Slave and browsing variables using Zenon IEC 60870-5-101_104 driver as Master. All Tags are communicating perfectly between Master and Slave, but could not write value from Master (Zenon). We have found following Error in execution. Kindly provide solution as soon as possible.
    Warm Regards
    Srikanth G
    Attached Thumbnails Attached Thumbnails Diagose error for Master configuration - Copy.png
    28.02.2013
    222
    Default Re: IEC 60870-5-101_104 Value Write Issue
    Dear Srikanth,
    in IEC 60870 there are special variable types for communicating either in monitoring (from slave to master) or in command (from master to slave) direction.
    It seems that you are trying to write a value (on master side) to a variable that is for monitoring which is not allowed.
    Please configure an additional variable in command direction for writing values to the slave.
    Felix
    Dear Felix,
    We have done Fieldbus Configuration : IEC60870 slave as per attachment and Created Variables " T45 Single command " as a type identification COA=1,IOA =5. When we are trying to browse from Master (Zenon Driver) IEC 60870. respective variable is not browsing (invisible) .
    we cant even see variables from T30 in the master browsing .
    Warm Regards
    Srikanth G
    Attached Thumbnails Attached Thumbnails IEC60870 Import variable list - File.png   IEC60870 Configuration File.png
    28.02.2013
    222
    Dear Srikanth,
    due to protocol restrictions for IEC 60870 the online browsing for variables only works for variables in monitoring connection.
    Types like T30 need to be configured manually on zenon side.
    Please refer to the driver docu for details:IEC870 > Creating variables > Creating variables by importing > Online import
    Felix
  1. Write set value retentive
    Last Post: 14th November 2014, 12:47
  2. Write value on login/out
    By dlamarche in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 6th September 2013, 00:31
  3. Can I write a DynProperties in Runtime?
    By fransiska in forum VBA
    Last Post: 29th August 2013, 04:51
  4. IEC 60870-5-101_104 startup
    By lunzer in forum zenon Energy Edition
    Last Post: 21st April 2010, 14:47
  5. IEC 60870-5-101_104 startup
    By lunzer in forum Drivers
