Thread: I want a from date time and to date time of report filter in my rdl file
    28.05.2016
    3
    Default I want a from date time and to date time of report filter in my rdl file
    Dear all,
    I'm using zenon 7.50 with build 49034, i want From DATE TIME and TO DATE TIME of time filter to my rdl file ,
    i'm linking my report function to absolute time filter with propose current date and time
    from the above picture if i put from and to date and time filter that i want in report file
    i want that particular to display in from and to in my report file
    Default Re: I want a from date time and to date time of report filter in my rdl file
    Hi saikiran,
    You should be able to get this information into your report by adding the dataset containing the filter data to the screen switch function and use the appropriate fields from this dataset.
    28.05.2016
    3
    Hi saikiran,
    Thank you markclemens for the fast reply, actually i've checked the fields , those its not possible to link to any variable, if its links to variables only i can have access to put in data set know,
    if you have solution can you provide any small backup, so that i can do accordingly
  1. CEL file date within Zenon
    By mattsd in forum zenon Operator
    Last Post: 5th February 2014, 16:01
  2. Read Date & Time from Time Attribute on IEC61850
    By salmanhassan2 in forum zenon Energy Edition
    Last Post: 22nd February 2013, 07:34
  3. Read Date & Time from Time Attribute on IEC61850
    By salmanhassan2 in forum Drivers
  4. date and time display using variable
    By paruvathakumar in forum zenon Supervisor
    Last Post: 22nd January 2013, 14:58
  5. Changing date & time of a panel during runtime
    By batabaha in forum zenon Operator
    Last Post: 15th April 2012, 23:35
