Thread: Raspberry Pi connection to Zenon
    09.01.2014
    9
    Default Raspberry Pi connection to Zenon
    is there any possibility to connect a Raspberry Pi to a Zenon Runtime?
    I prefere a TCP/IP Hardware if possible. Of cause, if there is a other easy Interface-Solution. Please tell me.
    Thanks for your Help !!
    BR
    Seba
    18.12.2017
    24
    Default Re: Raspberry Pi connection to Zenon
    Hi Seba!
    zenon Logic have a Runtime that should work on Raspberry Pi. It depends on what OS you have installed. Most Linux distros are fine.
    Then I would recommend the stratonNG protocol.
    Otherwise you can use ModBus TCP. There are a lot of open libraries on the net for that.
    /Fredrik
    09.01.2014
    9
    Hello Frederik!
    Thanks for answering !!
    You would propose to connect raspberry pi via Modbus TCP.... I will try to do so.
    Thanks a lot !!
    BR
    Seba
    18.12.2017
    24
    Hi!
    I guess you are using Python on your Raspberry Pi.
    This is a popular library:
    https://github.com/riptideio/pymodbus
    Br
    Fredrik
    02.12.2019
    Thank you!
  1. Recieving Goose on Raspberry Pi (Straton)
    By jonastj in forum straton / zenon Logic
    Last Post: 15th June 2015, 14:08
  2. Connection Straton<-->Zenon
    By agh_team in forum straton / zenon Logic
    Last Post: 20th August 2014, 20:13
  3. Connection to zenon
    By churras in forum straton / zenon Logic
    Last Post: 4th August 2014, 12:01
  4. Replies: 2
    Last Post: 4th June 2013, 10:18
  5. connection failed between zenOn and STRATON
    By bernhards in forum straton / zenon Logic
    Last Post: 21st August 2007, 07:52
