Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 13
Thread: Process Gateway
    29.08.2009
    LEGAZPI CITY
    56
    Default Process Gateway
    Im working right now with Zenon process gateway, as per my understanding in your documentation.
    Whenever you run the zenProcGateway.exe during RT, it will show you what protocol interface you want to select ( like DNP. Modbus, SNMP, etc.) and after you selected the protocol you want. It will show you all the variables available in your project and let you select what variables you want to export. Am I right?
    But in my case, i already made RT for my project and whenever I run the zenProcGateway.exe, it always shows this message" the process gateway cannot connect to the Runtime.Please start the Runtime first"
    what seems d problem? did i missed some configuration ?
    Default Re: Process Gateway
    could you please check in your zenon6.ini if the entries are set:
    [VBA]
    EIN=1
    EVENT=1
    The process gateway is using the COM interface of zenon, this interface is also deactivated if VBA is deactivated
    29.08.2009
    LEGAZPI CITY
    56
    Hi Bernhards!
    I checked in the folder Program Files/ COPA-DATA/zenon 6.22 SP1 but I cannot locate it.
    where can i find that zenon6.ini file?
    sorry for the missing information,
    you will find the zenon6.ini at "C:\ProgramData\COPA-DATA\System\zenon6.ini"
    29.08.2009
    LEGAZPI CITY
    56
    I located the file and the entries are set:
    [VBA]
    EIN=1
    EVENT=1
    It is not clear for me, did you also start the zenon RT before you start the process gateway
    29.08.2009
    LEGAZPI CITY
    56
    yes, i started the zenon RT before i start the process gateway
    As far as I remember, there must also be the name of the project running within the zenon runtime be entered into the zenProcGateway.ini
    So check if the project name of your project is mentioned within the zenProcGateway.ini!
    29.08.2009
    LEGAZPI CITY
    56
    [PATH]
    GRAPHIK=\Graphics
    EXPORTPFAD=\Export
    BITMAP=\Bitmaps
    ZUORDNUNG=\Allocation
    LISTEN=\Lists
    VIDEO=\Video
    REPORTS=\REPORTS
    BACKUP=\Backup
    EXPORTARV=\ExportArv
    BILDER=\Pictures
    ONLINE_HELP=\ONLINE_HELP
    EXE=C:\Program Files\COPA-DATA\zenon 6.22 SP1\
    VBF30=C:\Users\Public\Documents\zenon_Projects\PRO JECT1\WARD
    [DEFAULT]
    ;ACTIVATIONKEY5=
    ;SERIAL5=0.90fbfcf.0.0.3001f ;Demo SerialNr.
    ACTIVATIONKEY5=****************
    SERIAL5=****************
    SERIALIZE=1
    LANGUAGE=ENGLISH
    DEFWORKSPACE6=C:\Users\Public\Documents\zenon_Proj ects\PROJECT1\Project1.wsp6
    LASTPROJEKT=WARD
    DEFANWENDUNG30=WARD
    [FRM_PRNT]
    LINES=72
    [SIMULATOR]
    DWBEGIN=9999
    DWEND=9999
    FLOATBEGIN=9999
    FLOATEND=9999
    OFFSET=0
    UPDATE=1000
    [BTB]
    EIN=1
    NAME=BTB
    SOLLWERT=0
    [FUNKTIONEN]
    EIN=1
    ZURUECK_ANZAHL=10
    REZEPT_AENDERN=0
    [STATISCH]
    SUCHE=5
    [EDITOR]
    WINDOW=1,67,94,227,130
    RASTER=1
    WORKSPACEVIEW=1
    [MATHDRV]
    TIMER_TIME_OUT_IN_SEC=0
    [ARCHEDIT]
    ARCHEDITFONT=-13,0,0,0,400,0,0,0,0,3,2,1,49, Courier New
    DATUMBREITE=18
    EINHEITBREITE=10
    STATUSBREITE=15
    VARIABLEBREITE=10
    WERTBREITE=10
    ZUSTANDBREITE=10
    [ListenFont]
    Hight=-13
    Weight=700
    Italic=0
    Underline=0
    Pitch=34
    Face=Arial
    [SYSTEMTREIBER]
    UPDATE_SEK=5
    [EDITOR]
    LASTWORKSPACE=1
    EINGABE_SOFORT=1
    [VARLISTBOX]
    SINGLE=10,100,750,425
    MULTI=10,100,750,465
    Symbols=835,233,1151,586,50,120,0
    [VBA_TOOLBAR]
    VBAButton_2=ActivateStartupScreen
    VBAButton_0=ShowWizard_Language
    VBAButton_1=ShowWizard_Docu
    VBAButton_3=
    VBAButton_4=
    [RT]
    DRIVER_HIDE=1
    DRIVER_COUNT=0
    [Simulation driver Start]
    Rampe=0
    Obergrenze=65535
    Untergrenze=0
    Schrittweite=1000
    [Driver for Simulator Variable]
    Rampe=0
    Obergrenze=1000
    Untergrenze=0
    Schrittweite=10
    [PROPERTY]
    VIEW=0
    SHOWFAVORITES=0
    SORT=0
    SHOWALL=1
    DESCRIPTION=1
    [WSP]
    COL1=174
    COL2=0
    [RECENTWORKSPACES]
    WORKSPACE0=C:\Users\Public\Documents\zenon_Project s\PROJECT1\Project1.wsp6
    WORKSPACE1=C:\Users\Public\Documents\zenon_Project s\DEMO622.WSP6
    WORKSPACE2=
    WORKSPACE3=
    WORKSPACE4=
    [PROFILE]
    PROFILE0=0
    PROFILE1=0
    PROFILE2=0
    PROFILE3=0
    PROFILE4=0
    PROFILE5=0
    PROFILE6=0
    PROFILE7=0
    PROFILE8=0
    PROFILE9=0
    PROFILE10=0
    PROFILE11=0
    PROFILE12=0
    PROFILE13=0
    PROFILE14=0
    PROFILE15=0
    PROFILE16=0
    PROFILE17=0
    PROFILE18=0
    PROFILE19=0
    PROFILE20=0
    PROFILE21=0
    PROFILE22=0
    PROFILE23=0
    [SIMUL_WIZ]
    Rampe=1
    Obergrenze=1000
    Untergrenze=0
    Schrittweite=10
    [AlarmFilterDialog]
    Index1=1
    Filter10=*
    Index2=1
    Filter20=*
    [SIMULATORDRIVER]
    Rampe=3
    Obergrenze=1000
    Untergrenze=0
    Schrittweite=50
    [DEBUG]
    OWN_EXCEPT_HANDLER=0
    [SYMBOL]
    [VBA]
    EIN=1
    EVENT=1
    [VSTA]
    ON=0
    CSHARP=1
    [Recent Picture List]
    Picture1=Picture 0
    29.08.2009
    LEGAZPI CITY
    56
    thats the complete txt file inside the zenon6.ini, u can see there the project name is WARD.
  1. Process Gateway IEC870SL
    By lunzer in forum Drivers
    Last Post: 8th August 2017, 12:28
