Thread: non-linear value adjustment macros - how to set values without endless loop?
    07.11.2016
    3
    Default non-linear value adjustment macros - how to set values without endless loop?
    after long searching and trying I came to no result.
    These options are poorly documented and I didn't find any examples.
    In the help one can find this:
    AdjustScadaValue
    Only available, if non-linear value
    adjustment is active
    Macro is executed when setting a value in the
    control system to update the raw value (PLC).
    AdjustHardwareValue
    Macro is executed with every change of the raw
    value (PLC) to update the value in the control system.
    I have no idea how I can set the value in these macros
    I tried it by setting obVar.Value = someValue wich results in an endless loop as the macro is called immediately when the value is set.
    How to tell the system that I want to set the hardware value or the control system value vice versa…?!
    Thank You,
    Stephan
    13.08.2013
    57
    Default Re: non-linear value adjustment macros - how to set values without endless loop?
    setting the obVar.Value will result in an endless loop, try this instead
    Public Function AdjustZenOnValue_Scaling330KV(obVar As Variable, vValue As Variant) As Double
    On Error Resume Next
    Dim W As Variant
    'Diese Function wandelt z.B. einen Sollwert in den BCD Code um,
    'damit dieser korrekt in die Steuerung abgesetzt werden kann
    W = vValue
    AdjustZenOnValue_Scaling330KV = W / 10
    End Function
    Public Function AdjustHardwareValue_Scaling330KV(obVar As Variable, vValue As Variant) As Double
    Dim W As Variant
    W = vValue
    AdjustHardwareValue_Scaling330KV = W * 10
    End Function
    Best regards
    07.11.2016
    3
    thank You for the answer - seems like I'm out of practice with VBA
    I've failed to see the
    Code:
    AdjustHardwareValue_xyz(obVar As Variable, vValue As Variant) As Double
    and also forgot how to return values in VBA functions wich is done by assigning the function name the desired value
    Code:
    AdjustHardwareValue_xyz = myValue
    Ok, so this is working for me, now
    BUT - next problem: the values are set in the plc but zenOn doesn't update the values on the pages…
    any ideas?
    Cheers, Stephan
    07.11.2016
    3
    Sorry for bothering... I had a typo in the functionname
    Thank You & cheers, Stephan
  1. Logic, a loop for an array with type variables
    By genakust in forum straton / zenon Logic
    Last Post: 9th May 2018, 07:18
  2. VBA macros not appearing
    By dnaf in forum VBA
    Last Post: 6th April 2017, 08:29
  3. change "Value adjustment linear"
    By boykooo in forum VBA
    Last Post: 5th October 2015, 09:09
  4. non-linear value adjustment
    By sebastiank in forum VBA
    Last Post: 24th May 2013, 04:30
  5. My workspace Macros?
    By softart2 in forum VSTA
    Last Post: 27th December 2010, 00:58
