Thread: Message control zenon6.ini
    Default Message control zenon6.ini
    I have noticed that the zenon6.ini file are not the same on the primary server and the standby server.
    I am configuring an SMTP functionality and I noticed that I need to copy the [Message Control] section from zenon6.ini file on the editor PC to the zenon6.ini file on the SCADA server.
    Should I copy this also on the standby server seeing that the zenon6.ini files are not identical?
    If I don't copy it, will the standby server be able to send e-mails when the primary server crashes?
    Kind regards,
    Razvan
    27.12.2016
    Default Re: Message control zenon6.ini
    Yes, you need to enter the part about message control in the zenon6.ini in the server and in the runtime server.  copy the [Message Control] is a good solution.
    Best regards, Michael
  1. message control : notification message in cel
    By SOFIANE in forum zenon Network
    Last Post: 16th July 2019, 09:40
  2. Message Control - SMS
    By stahlheber in forum zenon Supervisor
    Last Post: 12th September 2014, 10:47
  3. Message Control
    By navaneet in forum zenon Network
    Last Post: 2nd May 2014, 12:00
  4. Replies: 0
    Last Post: 27th September 2007, 13:17
