Thread: Archive XX Data couldnot be read completely. Please set a shorter time priod.
    01.02.2016
    8
    Default Archive XX Data couldnot be read completely. Please set a shorter time priod.
    One archive created with 80 variables, type real.
    Make screen with control element DiagramWindow, and show 4 variables.
    when try to switch to screen with this control Iget message:
    I used for Time, this settings Relative time period 00 days 12 hours 00 min 00 sec.
    02.05.2017
    24
    Default Re: Archive XX Data couldnot be read completely. Please set a shorter time priod.
    Hello milosh,
    this message normally occurs when the RAM is exceeded.
    - How many actual value change points are inside the archive in this time period? How large is the archive file?
    - Are you using the 64 bit editor & runtime?
    - What, if anything, is configured inside the project.ini under [ARCHIV]/SPEICHER? (Help: 'Manual > Configuration files > project.ini > Historian [ARCHIV]')
    - Is it possible that only a small amount of RAM on your PC is available anymore when this occurs?
    - Does it work with a shorter time period?
    Lukas
  1. Read Date & Time from Time Attribute on IEC61850
    By salmanhassan2 in forum zenon Energy Edition
    Last Post: 22nd February 2013, 07:34
  2. Read Date & Time from Time Attribute on IEC61850
    By salmanhassan2 in forum Drivers
  3. Archive xx uncompletely read message
    Last Post: 14th October 2012, 23:12
  4. Read data from backup folder
    By slaff in forum VSTA
    Last Post: 4th April 2011, 23:12
  5. How can I read this two type of Data register?
    By michael_k in forum Drivers
    Last Post: 24th November 2009, 16:23
