Showing results 1 to 7 of 7
Thread: Variable XML export/import
    31.10.2018
    4
    Default Variable XML export/import
    Hi to all!
    Story goes like this.
    I have successfully exported all variables to XML file. I have made some changes to XML file (for example: field for showing variable limit value in AML changed from FALSE to TRUE) and saved it.
    After the changes I have imported the new XML file successfully to Zenon but even the changed fields in XML file are on TRUE, the fields in Zenon project remained on FALSE.
    Can somebody tell me where I'm doing wrong? Do I need to change some other field too?
    I would like to change like this some other fields beside checkbox for showing in AML:
    - checkbox for showing in CEL
    - Tagname
    - Limit value text
    I hope somebody can help me.
    02.05.2017
    31
    Default Re: Variable XML export/import
    it sounds like you have only set 'FlagIsAlarm' to true. If that's the case, you have to add a new XML tag within the desired 'Limits' tag with the name 'Alarm' and also set that to true
    For showing in CEL, create the XML tag 'Cel' inside the limit tag, set it to true, and also set 'FlagToCEL' to true.
    For changing the tag name, change the attribute 'shortName' of the desired variable and also the 'Name' tag
    For changing the limit value text, add a new XML tag 'Text' inside the Limit tag and put your string into there.
    Unfortunately the forum doesn't like XML code, so here's an example screenshot
    Best Regards
    Lukas
    31.10.2018
    4
    Hi LukasRotter,
    thank you for quick answer!
    For showing in AML and CEL is now all clear.
    I don't need to change "ShortName" but "Tagname" field in XML file (that is "Identification" field when you open General tab for variable in Zenon).
    I tried to do it and I made the updated XML with new name, but when I import that file into Zenon project Identification field remains the same. Is there also some flag I should change to TRUE?
    For Limit.Text field I think that I have to change FlagMessage to TRUE if I want Zenon to accept the new string.
    02.05.2017
    31
    I don't know of such a flag. I just tried it with a new variable and the change of the identification worked for me. Could you maybe attach your XML file or a shortened version of it? (Forum doesn't like XML code directly inside of the post)
    Correct, I forgot to mention that.
    31.10.2018
    4
    Please find file attached.
    For example, I tried to change Tagname for TIA1HHA40CT003.O_ALARM_HH_ACT from "@alarm HH" to "@alarm HH 111" with no success.
    02.05.2017
    31
    Try to set the XML tag "IsLocalTagname" of the variable to TRUE. If it is set to FALSE, the tagname will be automatically taken from the datatype.
    Best Regards
    Lukas
    31.10.2018
    4
    Thanks, it works :-).
  1. Treiberkonfiguration Export/Import XML
    By jusufs in forum Drivers
    Last Post: 5th July 2016, 08:54
  2. VB.NET - Windows Form Export/Import
    By idkj in forum VSTA
    Last Post: 4th May 2015, 14:45
  3. Import/export mathematics variables
    By webrazor in forum zenon Service Engine Supervisor
    Last Post: 24th April 2015, 09:53
  4. Historian import and export
    By natasjagts in forum zenon Service Engine Supervisor
    Last Post: 23rd May 2012, 13:36
  5. Export And Import of XML
    By allmendinger in forum zenon Service Engine Supervisor
    Last Post: 24th April 2008, 07:44
