Thread: Reg: Evacuation in sql not visible for Project IDs
    29.04.2014
    26
    Default Reg: Evacuation in sql not visible for Project IDs
    Hi All,
    Project ID is not listing in table creation for sql during historian archive.
    Please support what might be the issue?
    Sarav
    10.12.2007
    191
    Default AW: Reg: Evacuation in sql not visible for Project IDs
    I think what you mean is that there is no database to choose from the server. Maybe that's because you try to connect via WindowsNT integrated security.
    Usually the Zenon_2012 Server instance only has a user zenOnSrv, so you should switch to specific username and password and try to connect with the user zenOnSrv (Password depends on the first zenon Version that installed the SQL Server 2012, Try srv_710 or zen_$2012)
    28.02.2013
    190
    Default Re: Reg: Evacuation in sql not visible for Project IDs
    Dear Sarav,
    please be aware that the database instance "zenon_2012" is a central part of the zenon engineering system and used for storing project configuration, etc.
    From a system architecture point of view it should not be used to store process data.
    Please use a different DB instance for that.
    Felix
  1. Styles content is not visible in Zenon 7.60
    By rahulindore05 in forum zenon Supervisor
    Last Post: 12th May 2018, 08:14
  2. Web Client - Visible Scrollbar on Internet Explorer in full screen mode
    By steven.costantini in forum Webserver / Webclient Setup
    Last Post: 15th February 2017, 09:22
  3. Redundant Servers - SQL Evacuation
    By adrian.mcgranaghan in forum zenon Supervisor
    Last Post: 24th April 2015, 19:16
  4. Replies: 12
  5. action "COMMAND" at the dynamic element not visible
    Last Post: 16th May 2008, 06:53
