Thread: Creating all in to PDF
    Default Creating all in to PDF
    Dear Team,
    Can we export all reports into PDF which we are Viewing in LOT Filter.
    Instead of opening each and printing -- can we do all Lot filter files
    Warm Regards
    Srikanth G
    25.06.2012
    157
    Default Re: Creating all in to PDF
    Dear Srikanthg,
    Report Viewer allows to export the data to PDF using three different methods:
    - Screen type embedded control element: "Create PDF" button in the screen.
    - Standard zenon function: "Report Viewer: export/print". Allows to set up automatic filtering, inc. Lot filter.
    - Softprint printing to PDF file.
    I believe you are looking for solution #2. In this case, you can link the respective functions to "Time Control", so that they are executed at a certain time, or to an event (variable limit) that triggers the execution of the functions. It is also possible to create a zenon script that includes all "Report Viewer: export/print" functions and allows the export of all reports at the same time - it this case, beware that the reporting renderization process can take a considerable amount of CPU and time.
    Thank you very much.
    David Cerdeira
  1. help with creating variables zenon 6.51
    By martinrelayer in forum zenon Service Engine Supervisor
    Last Post: 2nd March 2018, 18:51
  2. Problem with Treiberkit760_SP0 when creating new driver
    By dobby in forum zenon Energy Edition
    Last Post: 15th August 2017, 08:34
  3. creating a table in zenon
    By lmucha in forum zenon Service Engine Supervisor
    Last Post: 1st June 2017, 10:31
  4. creating a table in zenon
    By lmucha in forum VSTA
    Last Post: 24th April 2017, 10:05
  5. Creating runtime files
    By scotttee in forum zenon Service Engine Supervisor
    Last Post: 22nd July 2009, 15:19
