Thread: Edit User screen control elements
    01.11.2012
    59
    Default Edit User screen control elements
    Dear colleagues,
    I am looking for advise how to handle the issue.
    The design-time environtmens is Zenon 7.60 SP0 Build37399 32Bit
    The run-time environments is Zenon 7.20 SP0 Build17768 32Bit
    Project\General\CreateRuntimeFilesFor is set to Zenon 7.20SP0
    There is a Screen with the type of "Edit user"
    From "Control elements" menu the set of elements placed on it.
    Text edits:
    User name
    Complete name
    Old password
    New password
    Confirm password
    Switchches:
    Administrator
    Active
    Locked
    Non of them displayed on the run time.
    When thele elements are replaced by the similar ones from Control elements\Compatible elements submenus, they are displayed fine but they don't handle Edit/New difference for Current password and user name fields.
    How can I make standard elements displayed in RT?
    Kind regards,
    Sergiy
    816
    Default Re: Edit User screen control elements
    While editing project in 7.60 Editor for 7.20 Runtime, please make sure that you are using only elements available in 7.20, as in the Runtime the new elements are simply not there.
    01.11.2012
    59
    Dear Ursula,
    Thank you for reply. It is fair enough to expect the same versions for DT and RT.
    One more question, if you don't mind.
    Is it possible to update Zenon 7.2 to the 7.6 under the existent license? Would I be required to re-activate it?
    Kind regards,
    Sergiy
    816
    It depends on license you have. So, contact your local COPA-DATA Sales representative, my collogues will guide you.
    01.11.2012
    59
    Thank you.
    Kind regards,
    Sergiy
  1. Text padding in screen elements feature request
    Last Post: 25th October 2018, 09:57
  2. Replies: 0
    Last Post: 13th October 2017, 16:51
  3. Size dynamic for ActiveX and Control Elements
    Last Post: 12th December 2013, 11:34
  4. User Control
    By navaneet in forum zenon Supervisor
    Last Post: 8th October 2013, 04:26
  5. additional control elements in a keyboard picture
    Last Post: 17th October 2007, 16:25
