Thread: how to share variable from external PLC to other PLCs in the network using Zenon SCADA
    Default how to share variable from external PLC to other PLCs in the network using Zenon SCADA
    I am reading wind data from Delta PLC using Modbus TCP/IP. I want to send this wind data to other PLC Slaves(Delta) in the network using Zenon SCADA. Is this possible without using Zenon Logic?
    Lingelethu Dyasana.
    10.12.2007
    204
    Default AW: how to share variable from external PLC to other PLCs in the network using Zenon SCADA
    You only need an allocation. Choose Source an destination Variable - that's it.
  1. Replies: 2
    Last Post: 27th August 2018, 10:08
  2. zenon logic doesn't communicate with external variables in zenon
  3. Re: zenon logic doesn't communicate with external variables in zenon
  4. Minimal external variable change interval to be hooked in zenOn
    Last Post: 24th September 2013, 18:38
  5. Managing redundant PLCs
    By vasco in forum zenon Network
    Last Post: 19th April 2010, 13:58
