Showing results 1 to 7 of 7
Thread: Sub Project in Webserver Pro Lite
    10.05.2017
    68
    Frage Sub Project in Webserver Pro Lite
    Hello Team.
    I have got a Web Server Pro Lite license 3 Clients.
    I have one main project and one sub project inside the main project. Neither of them are client projects. I have linked the sub project to my main project via screen switch and vice versa.
    Now will I be able to view the sub project also through my Web client.
    Please suggest
    Joel
    03.11.2015
    48
    Default Re: Sub Project in Webserver Pro Lite
    Quote Originally Posted by joelprasad View Post
    If you have a lite license, your sub project and main project must be hosted over the PC where your web server is running. Then you should be able to use subprojects with your Web client.
    10.05.2017
    68
    Frage Re: Sub Project in Webserver Pro Lite
    Quote Originally Posted by joris.l View Post
    Hello Joris,
    If the sub project is a client project, then is there any restrictions with Lite version?
    Joel
    03.11.2015
    48
    Hello Joris,
    A client project works also on a Web Client - but it has to be ensured that the nessesary variables are available/can be connected over the client project.
    BR,
    Joris
    10.05.2017
    68
    BR,
    Joris
    Hello Joris,
    can you confirm that, a project configured as client can be Accessed via Webserver Pro Lite version. It is mentioned in the Copa Data manual that its does not supports. Screenshot attached
    Joel
    03.11.2015
    48
    Sorry if this was not clear. When there is a Lite Web Server in use, Client projects (Which have a server elsewhere than where the Web Server Lite is running) are not supported.
    Only runtimes running on the same PC will get a connection.
    10.05.2017
    68
    Daumen hoch Re: Sub Project in Webserver Pro Lite
    Thank You Joris
    Joel
  1. How can i start webserver
    By marcelodias in forum Webserver / Webclient Setup
    Last Post: 13th March 2017, 11:07
  2. Has WebServer in Demo mode WebServer or WebServer Pro functionality?
    By stolyarov_as in forum Webserver/Webclient
    Last Post: 2nd April 2014, 13:54
  3. WebServer connection
    By abcd1234 in forum Webserver/Webclient
    Last Post: 15th January 2014, 15:57
  4. WebServer - Project
    Last Post: 2nd January 2014, 15:57
  5. Replies: 12
