Thread: Embed symbol checkbox.
    09.03.2018
    8
    Default Embed symbol checkbox.
    I want to modify variables by zenon Logic, but cannot manage to check "Syb." checkbox in Straton. I'm getting message "The variable is currently locked".
    Any idea what should i do?
  2. #
    09.03.2018
    8
    Default Re: Embed symbol checkbox.
    OK, kind a way solved it!
    It seems that after update build, when i'm creating variable in VBA i need to manually set dynamic propertie "Adressparam".
    Variable.DynProperties("Adressparam") = ""
        // "<syb>" is included once (VBA wrap is getting it wrong
    This line did the trick.
  3. #2
    710
    a zenon variable, which is 'externally visible' for Logic, shall be still (re)configured only in zenon, not in Logic. And anyway its check-box 'Syb.' shall be activated, thus: why you want to change it manually?
  4. #3
    09.03.2018
    8
    OK. I think i found out it.
    In Zenon 7.6 Build 42944, after creating new variable and setting external visibility on, Logic can read and write variable value.
    After upgrading to Build 49532 after the same variable creation process, variable is visible in Logic but it can't read it nor write it.
    Is it a bug, or new build requires some additional configuration?
  5. #4
    Please ensure that you've also created the "logic to SCADA connection" driver in the fieldbus configuration of your zenon logic project.
  6. #5
    09.03.2018
    8
    I'm sure, "logic to SCADA connection" is created.
  7. #6
    09.03.2018
    8
  1. Picture in symbol
    By jessica in forum zenon Supervisor
    Last Post: 17th October 2014, 11:41
  2. Getting symbol name
    By dnaf in forum zenon Supervisor
    Last Post: 9th August 2013, 13:04
  3. uncheck "all entries" checkbox
    By fgenc in forum zenon Supervisor
    Last Post: 15th March 2013, 14:49
  4. alarm symbol
    By lunzer in forum zenon Supervisor
    Last Post: 22nd July 2009, 14:37
  5. Symbol drehen...
    By alice18 in forum zenon Supervisor
    Last Post: 15th January 2009, 16:45
