Hi All,
I set up an Extendend Trend screen with the Standard Scada 1920 template.
I configured the screen switch function to read 23 tags from 2 different Historian Archives, edited some curves names...
It works well on Editor Laptop, when i switch the screen all of selected plots appear, but on the RT PC the screen is empty...
On RT pc via the "Diagram" button (filter function) I'm able to manualy select data from archives, They seems work.
I tryed to reduce to 4 the number of tags called by ssw function, they correctly appears on RT PC...
Am I perhaps experiencing some license limit issue? what else?
Version 7.60 SP0 Build40751 32Bit
Thank you for your help
Regards
Federico
