Thread: Build Installation Errors
    Default Build Installation Errors
    Dear Team ,
    Most of the cases we are facing issue in installation of new builds, screenshots are attached.
    Can any one share links for Zenon 7.00 build 32 and Zenon 7.11 build 45643.
    Warm Regards
    Srikanth G
    Attached Thumbnails Attached Thumbnails 7.50 build error.png   8 build error.png
    15.01.2016
    92
    Default Re: Build Installation Errors
    Hello Srikanthg,
    Looks like that the build setup cant find your installed zenon try to open the startup tool of your zenon and click the "Standard" button this will reregister all filles and then try again.
    Best Regards
    Tobias Ritschel
    Dear ritschel93,
    Thanks you for your solution.
    I have done in multiple systems by
    "Standard" button (register all files) and then new build have installed perfectly.
    Warm Regards
    Srikanth G
  1. Zenon 7.20 SP0 build 17678 vs build 20554
    By sdolnyy in forum zenon Supervisor
    Last Post: 18th December 2017, 21:50
  2. Redundancy errors
    By diemon in forum zenon Network
    Last Post: 2nd April 2015, 08:17
  3. Replies: 0
  4. Errors when compiled
    By celeste in forum zenon Supervisor
    Last Post: 13th June 2010, 23:52
