Thread: Recipe not loaded properly
    04.04.2018
    Frage Recipe not loaded properly
    I have a problem with straton: I want to save+load some values using the integrated recipe manager.
    However it appears that some values are not saved/loaded properly !
    The same problem appears by saving or reloading values to/from the recipe.
    Here is a short video of the problem : https://www.youtube.com/watch?v=q6_Yp0iNMsg
    I am using Zenon 7.60.
    Is it a known problem ?
    What are the alternatives to backup and reload variable status?
    Thanks for your help !
    08.12.2015
    39
    Default Re: Recipe not loaded properly
    I see that the variable you are trying to write are in a structure with tables of structures etc.
    Around how many variables are you trying to write in the recipe?
    I don't know the exact number in terms of variables, but, yes, there is a limit here.
    (Normally the runtime should output an error when trying to write too many variables, even in simulation…)
    The explanation is that when sending this command (send/load), every variables must be written at the same time. In order to do that, these are all embedded in a same frame, and this frame has a size limit of 1ko.
    What you can try is first of all to check the Following option in the project settings:
    Right-click on the project > Settings > General > Complex variables in a separate segment > Yes
    If this does not solve the problem, you must reduce the amont of sent variables.
    To do so, I see this solution: create several columns (initValues_1, initValues_2...) and send the recipe columns by columns.
    The best is eventually to directly create several recipe because when saving the recipe, this will be the same problem (too many data to handle), and in this case you cannot choose to save only small parts by small parts.
    I hope it helps,
    Anthony
  1. VSTA Project not working properly
    By jesus_michel in forum Add-In Framework
    Last Post: 14th February 2018, 22:12
  2. <Project 'F_GP7' not loaded>
    By iweinclaerhout in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 12th August 2014, 16:12
  3. zenon CE - BeckhNG.dll could not be loaded
    By ptkdennis in forum Drivers
    Last Post: 16th April 2014, 07:53
  4. Replies: 5
    Last Post: 3rd August 2011, 17:24
  5. Variable was not loaded
    By craigdouglas in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 12th February 2009, 13:15
