Thread: Error while importing cfg file in comtrade viewer
    10.05.2017
    68
    Frage Error while importing cfg file in comtrade viewer
    Hello Team,
    I am facing an error while I import the .cfg file in the Comtrade viewer.
    I have attached the screenshot below.
    Please suggest a possible solution.
    It happens when I click on open button and select the .cfg file from the extraction folder.
    Joel
    942
    Default Re: Error while importing cfg file in comtrade viewer
    The message informs you that the content of the file is not compliant with the guildlines of COMTRADE standard. Possible solution: contact the vendor of the device and request the fix. Or correct the content of each received file manually using some text/hex editor. Or develop a tool correcting the files.
  1. Comtrade viewer issue
    By joelprasad in forum zenon Energy Edition
    Last Post: 14th March 2019, 14:44
  2. COMTRADE viewer
    By Geezerglide in forum zenon Energy Edition
    Last Post: 27th June 2018, 07:14
  3. Importing of values from text file to Runtime
    By Praveen Kumar Karthikeyan in forum zenon Energy Edition
    Last Post: 30th August 2017, 12:00
  4. Readout comtrade file
    By skywalker in forum Drivers
    Last Post: 6th August 2012, 16:08
  5. Importing CSV file
    By pakman in forum VBA
    Last Post: 26th March 2009, 19:26
