Thread: .DAT integration
    28.09.2015
    16
    Default .DAT integration
    Have a project that each machine cycle generates file DATA.DAT and writes new data. Content looks like this:
    20180822,04:07:45,18065,1.24
    20180822,04:08:08,18066,1.24
    20180822,04:08:30,18067,1.24
    i wold like to use last data variable (1.24) and see it in runtime, use in analizer and have historical archive of them.
    Any solution how can i cennect file with zenon?
    1,023
    Default Re: .DAT integration
    Is the DATA.DAT file already available on a PC with zenon installation? Or you ask also about file transfer?
    Possible solution would be to start zenon Logic Runtime on the PC/device where DATA.DAT is stored. You can program Logic to read and evaluate the file and put the data (value and timestamp) in a stratonNG variable.
    28.09.2015
    16
    DATA.DAT is output from machine.
    We need implament that data into SCADA system.
    We can't use any driver becouse its not direct PLC connection.
    File Driver can't be used also becouse structure needed
    is different then machine outputs (DATA.DAT).
    Does any example or tutorial how to integrate text based data into Zenon?
    1,023
    sorry, you haven't answer my question: is this DATA.DAT file still on some remote machine or you have it already on a computer where also zenon is installed?
    i wasn't talking about 'file driver' but about file transfer (sending a file via network).
    >File Driver can't be used also becouse structure needed is different then machine outputs (DATA.DAT).
    This was already clear from your first post.
    not directly, maybe a colleague has it but not me. Anyway, it is not so complicated task if you know basics about zenon Logic. Do you? Have you ever tried to create in zenon project a zenon Logic project too, and used then a stratonNG variable which value is delivered by zenon Logic?
    28.09.2015
    16
    Yes the DATA.DAT file is on same PC.
    I'm new to zenon and i will try figuruot how work with Zenon Logic.
  1. Integration of Alstom relays
    By jose.torres@indexum.com in forum zenon Energy Edition
    Last Post: 18th April 2018, 12:28
  2. Integration Project
    By jahidbagwan in forum zenon Service Engine Supervisor
    Last Post: 13th June 2016, 18:55
  3. Replies: 0
    Last Post: 22nd December 2015, 06:48
  4. Printing CEL/AML from Integration Project
    By yavaskoray in forum zenon Service Engine Supervisor
    Last Post: 28th May 2014, 09:42
  5. integration project
    By aurel in forum zenon Service Engine Supervisor
    Last Post: 9th January 2011, 23:20
