sorry, you haven't answer my question: is this DATA.DAT file still on some remote machine or you have it already on a computer where also zenon is installed?
i wasn't talking about 'file driver' but about file transfer (sending a file via network).
>DATA.DAT is output from machine.
>We need implament that data into SCADA system.
>We can't use any driver becouse its not direct PLC connection.
>File Driver can't be used also becouse structure needed is different then machine outputs (DATA.DAT).
This was already clear from your first post.
>Does any example or tutorial how to integrate text based data into Zenon?
not directly, maybe a colleague has it but not me. Anyway, it is not so complicated task if you know basics about zenon Logic. Do you? Have you ever tried to create in zenon project a zenon Logic project too, and used then a stratonNG variable which value is delivered by zenon Logic?
