Thread: Iec60870 104 slave driver process gateway
    10.05.2017
    68
    Frage Iec60870 104 slave driver process gateway
    Hello Team,
    I am using IEC60870 104 fieldbus in zenon logic as slave as a process gateway.
    I have added certain no. of IEC61850 double point information to the gateway. Now in the client side of the gateway I am getting readings like shown below:
    For off status in slave = 2 in client.
    For on status in slave = 0 in client.
    For faulty status in slave = 1 in client.
    According to iec standards
    0 should be intermediate
    1 should be off
    2 should be on
    3 should be faulty
    Please suggest on the above
    Joel
    831
    Default Re: Iec60870 104 slave driver process gateway
    in Logic, the IEC6870 Slave driver is not supporting "DPI/DPC mapping" (feature available in zenon iec870 driver and in Process Gateway IEC870Sl, and in all IEC61850 products). Thus, you cannot map DPI/DPC variable directly between 850 and 870 communication, you have to add additional variables and write small code in logic doing the mapping.
  1. Process Gateway - Modbus slave - Addressing details
    By saravanan1985 in forum Drivers
    Last Post: 16th February 2017, 09:41
  2. Process Gateway - Modbus slave - Addressing details
    By saravanan1985 in forum zenon Energy Edition
    Last Post: 7th February 2017, 18:32
  3. IEC60870 Slave - Unknown device 10x. dev: 0, tid: 0 ioa:0
    By steven.costantini in forum straton / zenon Logic
    Last Post: 25th July 2016, 08:39
  4. Replies: 1
    Last Post: 1st April 2013, 22:28
  5. IEC60870 Driver Communication Status
    By knubla in forum Drivers
    Last Post: 29th November 2012, 13:32
