Thread: 61850 remote server or client
    28.03.2018
    8
    Default 61850 remote server or client
    I have v7.6 Energy Edition communicating to 61850 IED servers. I need to set up remote 61850 access sort of like a process gateway.
    Are there any papers or KB posts regarding this?
    Does it require a second driver instance?
    1,033
    Default Re: 61850 remote server or client
    Do I understand correctly that you want to run in you zenon project an 850-Server delivering your process data to an upper system (control center?) via IEC61850 protocol? Then this is not in iec850 driver, the driver is an 850-client. In zenon Logic there is a fieldbus driver - 'IEC61860 Server with GOOSE'.
    As first you would have to prepare the suitable ICD-file - with the data model for this 850-Server.
  1. Server Client Problem
    By james.tin@bmwgroup.com in forum zenon Network
    Last Post: 28th August 2015, 15:51
  2. Problem with remote connection to Analyzer SQL Server
    By altera in forum Report Engine (former zenon Analyzer)
    Last Post: 8th July 2014, 15:07
  3. 61850 Server
    By junior in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 13th March 2014, 12:48
  4. Client as Standby Server
    By salmanhassan2 in forum zenon Network
    Last Post: 6th February 2013, 23:48
  5. Different OS on server and client machine
    By anemet in forum zenon Network
    Last Post: 14th September 2012, 08:14
