Thread: ZEN 7.20 b 23281 2 machines same plc same IP suggestion to not freak out?
    29.06.2018
    Default ZEN 7.20 b 23281 2 machines same plc same IP suggestion to not freak out?
    This is my first post, so, we are using dual LAN panel, win 7, same static IP on LAN 1 and DHCP on LAN 2, and we have the same machine with the same PLC and IP.
    LAN 2 is used in DHCP for remote assistance via VPN, the machines are connected to a consumer router wireless which is connected to the company LAN, this cause big trouble to ZENON when by any chance it close the runtime and re-open it, runtime stops to communicate with PLC, it seems that it can't find a unique PLC IP address, and it might be exactly like that.
    Any suggestion on why this happens? LAN 1 & 2 are on different sub classes it should not happens ( or maybe I not so expert ) or not? the thing is that for now I can't change the PLC/Panel IPs.
    Is there any trick on how Zenon communicate with PLC, how can it address them? If I am not wrong it would be enough that addressing could be done via MAC right? is there any option?
    Than you in advance,
    Matteo
    180
    Default Re: ZEN 7.20 b 23281 2 machines same plc same IP suggestion to not freak out?
    Hello Matteo,
    I do not fully understand.
    You have one panel with two LAN Ports, right?
    Port 1: Static IP (which?)
    Port 2: DHCP (what range?)
    And on Port 1 LAN there is a PLC, right?
    What type of PLC?
    What IP?
    What communication protocoll/driver do you use?
    29.06.2018
    This issue was solved, the problem was not related to Zenon. Another service we use to communicate created the issue.
    Thank you all.
    Matteo
    180
    Great! Thanks for your feedback!
  1. Can screen-switch on different resolution machines cause errors?
    By n.bulgarini in forum zenon Supervisor
    Last Post: 20th May 2011, 17:25
  2. Attribution : Nice solution for machines variables ?
    By julienk in forum zenon Energy Edition
    Last Post: 16th December 2010, 11:57
  3. Replies: 4
    Last Post: 29th November 2010, 08:28
  4. Same Project On Two Machines
    By allmendinger in forum zenon Supervisor
    Last Post: 13th September 2009, 19:02
  5. Structures and Variable Definition question/suggestion
    By flajoso in forum zenon Supervisor
    Last Post: 27th March 2008, 10:27
