Thread: SICAM 230 V7.0 Vbs Error
    01.08.2017
    Default SICAM 230 V7.0 Vbs Error
    Hi All,
    I have problem with SICAM 230 V7 runtime, while I running the runtime an error are coming, it said that MSCOMCTL.OCX is missing, then I copied the missing file from another engine and register . But the error still appear.
    Please suggest the possible solution.
    15.11.2016
    100
    Default Re: SICAM 230 V7.0 Vbs Error
    Moved this to VBA.
    But technically this is not related to zenon.
    You should be able to find help when searching for your issue on Google.
    This Microsoft Windows Common Controls OCX gets installed with Microsoft Office.
    If you don't want to install MS Office you need to check the registry:
    HKEY_CLASSES_ROOT\TypeLib\{831FDD16-0C5C-11D2-A9FC-0000F8754DA1}\
    And compare with your "other engine".
    Heope this helps.
    BR,
    Georg
    10.12.2007
    191
    Default AW: SICAM 230 V7.0 Vbs Error
    I think the MSCOMCTL.OCX is only available in 32bit. Maybe you started the RT in 64bit mode?
    15.11.2016
    100
    64 bit as introduced with 7.10. He has 7.00.
  1. SICAM 230 V7 Runtime Error
    By Arif Nurrohman in forum zenon Supervisor
    Last Post: 8th June 2018, 08:05
  2. Sicam 230 web Client - InitInstance Error
    By arrols in forum Webserver / Webclient Setup
    Last Post: 10th November 2016, 11:17
  3. SICAM 230 v7.20 runtime error
    By barry in forum zenon Supervisor
    Last Post: 28th July 2016, 15:53
  4. Sicam 230
    By yolovs in forum zenon Energy Edition
    Last Post: 13th June 2016, 08:46
  5. Need help with Sicam 230
    By Vladich in forum zenon Energy Edition
    Last Post: 16th February 2016, 11:30
