Page 2 of 2 FirstFirst 1 2
Showing results 11 to 20 of 20
Thread: Alarm List
  1. #11
    15.11.2016
    106
    Default Re: Alarm List
    You can call a RTFuntion via API:
    this.RtFunctions.Item("Functionname").Start();
    But if you want a cyclic execution its better to use Time Control.
    Configure in the project -> Time Control
    BR
  2. #12
    08.06.2018
    12
    Quote Originally Posted by georgk View Post
    BR
    Ok but if i want to avoid this street and go on with external integration to avoid touching zenon Software, how can i make it works the call and the relative export of alarmItems ?
    Did somebody reach this result ?
    Thanks in advance
  3. #13
    28.02.2013
    218
    You mean not touching zenon engineering at all?
    So your requirement is to connect to a zenon runtime and fetch alarm data without having the zenon enigineering available?
    So you don't know which functions are configured with what parameters within the zenon project?
    Felix
  4. #14
    08.06.2018
    12
    Felix
    Yes exactly, if i can i would like to keep them separated, with the runtime open, and my mini-extractor in background.
    Actually i'm am connected to the zenon Runtime but my problem is that the alarmItems("*") don't return any item.
    I'd expect that * would return ALL elements
  5. #15
    08.06.2018
    12
    Any other hints?
  6. #16
    28.02.2013
    218
    You need to work with a QueryFilter:
    Code:
                zProject.Alarm().ResetQueryFilter();
                zProject.Alarm().DynProperties["QueryFilter.IsFromFiles"] = true;
                zProject.Alarm().DynProperties["QueryFilter.EntriesCount"] = 100;
                zAlarmItems = zProject.Alarm().AlarmItems(".");
                for (int i = 0; i < zAlarmItems.Count; i++)
                    zenOn.AlarmItem zAlarmItem = zAlarmItems.Item(i);
                    Console.WriteLine(zAlarmItem.Tagname.ToString() + " Zeit: " + zAlarmItem.Timecomes.ToString());
    Felix
  7. #17
    08.06.2018
    12
    Code:
    Felix
    Thank you Felix.
    I tried your code, i get an error on ResetQueryFilter, my Interop.zenOn.dll probably does not contain that method.
    Anyway the count of the alarms is always 0.
  8. #18
    28.02.2013
    218
    What zenon version are you using?
  9. #19
    08.06.2018
    12
    7.0
  10. #20
    08.06.2018
    12
    I want to inform people who helped me in this thread that now i am able to export Alarms that are not acknowledged calling AlarmItems("*").
    The problem remains for the alarms that are acknowledged.
    I'll keep you informed.
    Thank you
  1. Time format in Event list & Alarm list
    By Mustafa.SA in forum zenon Energy Edition
    Last Post: 13th March 2018, 22:03
  2. Time format in Event list & Alarm list
    By Mustafa.SA in forum zenon Supervisor
  3. Alarm doesn't appear at alarm Message List
    By marco.naccini@goriziane.it in forum zenon Supervisor
    Last Post: 19th January 2018, 14:38
  4. Replies: 10
    Last Post: 20th October 2013, 23:53
  5. Problems with alarm list and alarm time
