Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 20
Thread: Alarm List
    08.06.2018
    12
    Default Alarm List
    Good morning forum,
    i'm new to zenon Integration.
    I would like to export all alarms from my zenon with an external C# program, i admit that i already search in the forum for a solution.
    This is my code:
    zenonApp = new zenOn.Application();
    zenonApp = GetObj(1, "zenOn.Application");
    projects = (zenOn.Projects)zenonApp.Projects();
    prj = projects.Item(0);
    alarm = prj.Alarm();
    al_items = alarm.AlarmItems("*");
    al_items.Count always return 0, why?
    Am i doing something wrong ?
    Or am i searching in the wrong method?
    Thanks in advance
    15.11.2016
    105
    Default Re: Alarm List
    The method should be correct.
    See: http://onlinehelp.copadata.com/help/760/com/html/Alarm-Methods-AlarmItems.htm
    Maybe the Projects.Item(0) is a Global-Project and thus does not have Alarms?
    Try with projects.Item("PROJECTNAME");
    Please note that you can easily export Alarms in zenon using the zenon function "Export AML/CEL".
    08.06.2018
    12
    Quote Originally Posted by georgk View Post
    Hi georgk, thanks for your quick reply.
    I did this try, but i get the same result.
    I printed project.IsGlobal and it returns false.
    If alarms are already read, do i find it in alarmitems or in another class? Maybe Archive ?
    I didn't mention it, but i'm doing these tests with zenon runtime opened.
    15.11.2016
    105
    I tested this and it worked.
    See attached Code.
    Hope this helps.
    08.06.2018
    12
    See attached Code.
    Hope this helps.
    This code also works, but items count returns 0 alarms, but as you can see in my attachment, alarms are present.
    10.12.2007
    216
    Default AW: Alarm List
    I think the standard filter AlarmItems("*") only returns alarms wich are still in the ringbuffer. In the screenshot i can only find alarms which are already gone (=historic). Therefore you may need different Filtersettings than "*".
    08.06.2018
    12
    Default Re: AW: Alarm List
    Quote Originally Posted by mst View Post
    Thank you for your reply, where can i find these filter types ?
    10.12.2007
    216
    Phew, good question...
    In help (v7.60) it says "...AlarmItems(String strFilter) As AlarmItems.... The filtering is not implemented at this time. For later use...."
    Maybe this isn't possible until now...
    28.02.2013
    216
    can we go one step back?
    Why do you want to access historical alarms via the API?
    This is quite slow and will also slow the zenon runtime down.
    I suggest to use a zenon standard function to exoprt the alarms to a file and go on using this file within your application.
    It is also possible to trigger the export via the API if needed.
    Felix
    08.06.2018
    12
    Felix
    The objective is to avoid manual operations, so i would like to implement something that export Alarms.
    Can you please tell me more about this?
    Thank you in advance
  1. Time format in Event list & Alarm list
    By Mustafa.SA in forum zenon Energy Edition
    Last Post: 13th March 2018, 22:03
  2. Time format in Event list & Alarm list
    By Mustafa.SA in forum zenon Supervisor
  3. Alarm doesn't appear at alarm Message List
    By marco.naccini@goriziane.it in forum zenon Supervisor
    Last Post: 19th January 2018, 14:38
  4. Replies: 10
    Last Post: 20th October 2013, 23:53
  5. Problems with alarm list and alarm time
