Thread: How many servers/connections can be added in a single iec-61850 driver & how many such iec-61850 drivers can be in a project
    29.04.2014
    26
    Idee How many servers/connections can be added in a single iec-61850 driver & how many such iec-61850 drivers can be in a project
    Hello All,
                    This is a typical question to know our limitation. So guys I hope I will receive an immediate reply pertaining it.
    1) How many Server connections can be made in a single IEC-61850 driver.
    2)How many maximum number of IEC-61850 drivers can be made in a single project(Consider only IEC-61850 & Modbus TCP exists in project)
    799
    Default Re: How many servers/connections can be added in a single iec-61850 driver & how many such iec-61850 drivers can be in a project
    theoretically: 4294967295. The limit is the size of Net Address setting.
    theoretically, in one zenon project you can create 255 (more or less, i do not remember exactly) drivers and/or instances of driver(s). You can understand this quantity as the quantity of entries in the list of created drivers you have in the project Variables - Driver node. It does not matter if these entries are instances of the same driver or different drivers.
    In praxis the limitations in quantities are not per design in zenon. The limits are the resources of your PC (memory, CPU, network traffic).
  1. SICAM 230 IEC-61850 Driver Crash
    By bhavin_bvm in forum zenon Energy Edition
    Last Post: 28th March 2017, 11:51
  2. IEC 61850 Edition 2
    By altera in forum Drivers
    Last Post: 26th April 2016, 11:27
  3. Iec 61850
    By nikabena in forum zenon Energy Edition
    Last Post: 2nd March 2015, 10:29
  4. Iec 61850
    By nikabena in forum Drivers
  5. Regarding to SOE of IEC 61850
    By gyu in forum zenon Energy Edition
    Last Post: 11th March 2014, 09:45
