Thread: Reg: Variables Will Impact Delay in Screen switch function in Runtime
    29.04.2014
    27
    Default Reg: Variables Will Impact Delay in Screen switch function in Runtime
    Dear Team,
    Thanks for the support.
    We have around 26,000 variables defined in our project and the screen switch function is responses slow (even overall the navigation response with delay)
    compare to projects having less variables.
    Could you suggest any option for this.
    Regards
    sarav
    995
    Default Re: Reg: Variables Will Impact Delay in Screen switch function in Runtime
    Check in Task Manager the load on cores of the CPU (not the sum CPU), probably the main thread of Runtime has more to do as the PC's Hardware is able.
    If a core is on >= 80% - update to version 8.00, Runtime is more multi-threaded. Take a faster PC or split the project to 2 projects with different PCs as zenon Network Server.
    If not - contact your local, official COPA-DATA Support (Forum is not support) to help you analyze the project.
  1. Manipulation 'Screen switch'-Rt-Function via C#
    By michael.winter in forum VSTA
    Last Post: 19th November 2014, 14:46
  2. Variables with delay and red square
    By luizmartinsbr in forum zenon Service Engine Supervisor
    Last Post: 9th October 2013, 23:07
  3. Replies: 2
    Last Post: 24th May 2013, 04:12
  4. Replies: 1
    Last Post: 24th April 2013, 04:50
  5. Function switch picture
    By yara in forum zenon Service Engine Supervisor
    Last Post: 8th December 2010, 06:40
