Thread: CE Button variable switch not working as toggle.
    25.05.2016
    6
    Ausrufezeichen CE Button variable switch not working as toggle.
    I have opened a past 7.50 project in zenon 8, which is running on a CE device however the project has variable switch buttons to toggle PLC variables which now isnt working.
    The button switch on the old project did toggle PLC variables.
    so far i have tried:
    • new buttons added
    • switching internal and PLC variables
    The button does work if switch and pushbutton but this only makes a momentary switch not toggle.
    Thanks.
    15.11.2016
    106
    Default Re: CE Button variable switch not working as toggle.
    Please Update the CE Runtime to the latest version.
    Tools -> Update Windows CE Runtime...
    BR,
    Georg
    25.05.2016
    6
    Ausrufezeichen Re: CE Button variable switch not working as toggle.
    Quote Originally Posted by georgk View Post
    BR,
    Georg
    Done it made no difference.
    15.11.2016
    106
    In that case I suggest to contact your local Support Team.
    As a short term solution you can replace the Buttons with Switch-Elements.
    BR,
    Georg
  1. Button visibility variable in vba
    By redjon in forum VBA
    Last Post: 25th November 2016, 11:48
  2. Button-Text aus Variable
    By jenny in forum zenon Supervisor
    Last Post: 28th February 2014, 08:05
  3. Dynamic text on momentary switch button
    Last Post: 8th May 2013, 08:30
  4. Bit Toggle
    Last Post: 8th November 2011, 23:30
  5. How to increment a variable on button press
    Last Post: 24th September 2008, 12:51
