Thread: Service - memory leak
    01.08.2018
    Default Service - memory leak
    Our service reads some data from archive each minute (using Thread). But when this service is running, Runtime memory increases continuously.
    Could someone help me to detect, what is wrong with this part of code:
        public class ServiceExtension : IProjectServiceExtension
            Thread t1;
            public void Start(IProject context, IBehavior behavior)
                t1 = new Thread(() => Calculation(context));
                t1.Priority = ThreadPriority.Highest;
                t1.Start();
            public void Calculation(IProject context)
                IRuntimeArchive RuntimeArchive = null;
                IEnumerable<IRuntimeArchiveVariable> ArchiveVariables = null;
                IRuntimeArchiveVariable ArchiveVariable = null;
                while (true){
                    try{
                        //Gets necessary archive of the project
                        RuntimeArchive = (from X in context.RuntimeArchiveCollection where X.Name == "1MIN_1D" select X).First();
                        if (RuntimeArchive == null){
                            Debug.Print("No archive available!");
                            return;
                        //Gets variables
                        ArchiveVariables = (from X in RuntimeArchive.VariableCollection where X.Name.Contains(".ActivePower") && X.AggregationType.ToString().Contains("Average") select X);
                        foreach (var item in ArchiveVariables){
                            //Get variables
                            ArchiveVariable = (from X in RuntimeArchive.VariableCollection where X.Name != null && X.Name == "ActivePower" select X).FirstOrDefault();
                            //some logic
                    catch (Exception e){
                        Debug.Print(e.ToString());
                    //Wait at least 1min
                    Thread.Sleep(60000);
    Thanks!
    15.11.2016
    100
    Default Re: Service - memory leak
    A common RAM leakage in Code with Archive-reading and writing is caused by the ArchiveFilters.
    ArchiveFilters are created and used.
    But those ArchiveFilters are never deleted.
    Is that the case here?
    BR,
    Georg
    24.05.2014
    10
    Default AW: Service - memory leak
    You will never get out of the while loop?
    In my opinion your Code is not in a minute cycle.
  1. archive memory leak.
    By backjahyun in forum VSTA
    Last Post: 30th May 2016, 10:30
  2. Zenon 7.11 as service
    By diemon in forum zenon Supervisor
    Last Post: 4th March 2015, 10:22
  3. Free memory (%) variable - for what kind of memory?
    Last Post: 4th June 2013, 15:26
  4. Binding string variable to WPF, data leak?
    By sebastian.lenk in forum VSTA
    Last Post: 27th January 2013, 06:47
  5. Memory Leak when using IArchiveFilter.Query()
    By stolyarov_as in forum VSTA
    Last Post: 13th September 2011, 13:02
