Thread: Reg: Warning when using 7.11 project in 7.60
    29.04.2014
    28
    Default Reg: Warning when using 7.11 project in 7.60
    Dear Team,
    We are getting a warning when we used project of 7.11 in 7.60.
    Please refer attachmet screen shot
    Regards
    sarav
    10.12.2007
    273
    Default AW: Reg: Warning when using 7.11 project in 7.60
    Embedded Fonts are no longer supported in v7.60.
    There is a wizard in v7.20 which can be used to change embedded fonts to linked fonts. So you should first convert the 7.11 project to 7.20, run the wizard and afterwards you can convert to 7.60.
    If there are only a few embedded fonts used in the project, then you can also change them manually.
  1. Command REG-DA OLTC with IEC61850
    By sstoilov@gmail.com in forum zenon Energy Edition
    Last Post: 14th March 2018, 11:41
  2. REG-DA (IEC 61850) in Zenon 7
    By bnekooie in forum zenon Energy Edition
    Last Post: 19th January 2016, 14:47
  3. REG-DA (IEC 61850) in Zenon 7
    By bnekooie in forum Drivers
  4. Element Warning..
    By fatih.oz in forum zenon Energy Edition
    Last Post: 16th July 2014, 21:28
  5. Command REG-DA OLTC with IEC61850
    By sstoilov@gmail.com in forum Drivers
    Last Post: 16th May 2012, 11:37
