Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 13
Thread: how to convert the content of a variable in decimal into an hexadecimal value
    28.11.2017
    18
    Default how to convert the content of a variable in decimal into an hexadecimal value
    hi
    i would like to know how to to convert the content of a variable in decimal into an hexadecimal value
    08.12.2015
    39
    Default Re: how to convert the content of a variable in decimal into an hexadecimal value
    The value of a variable is always the same, in decimal, binary, hexadecimal... But you can view the hexadecimal form of a value, in debug (so while you are online or in simulation) doing a right-click on it > Hexadecimal display.
    If you want to recover the hexadecimal value of a variable in a STRING you can use the "HTOA" block.
    I hope it helps,
    Anthony
    28.11.2017
    18
    hi anthony
    i try to format a value from a DINT into an 8 bytes array
    1 bytearray[0]= 16#55 ascci code of 'U'
    2 bytearray[1]= 16#49 ascci code of 'I'
    3 bytearray[2] and  bytearray[3]= 16#01 index in hexa of my destination array
     bytearray[4]  bytearray[5] bytearray[6]  bytearray[7] value in hexa of my parameter
    so i am doing a serialize out to fill my value array but the user input the value in decimal i want to write it in the array in hexa
    08.12.2015
    39
    Hi !
    Mmmh... You mean, for example, the user is writing "85" (decimal value of 16#55) but you do not want to write "85" in your array of BYTEs, you want to have "55" (because it's the hexadecimal value), right?
    Then I think you can use the HTOA block this way:
    MyHexValue_0 := HTOA(DecimalUserValue_0); // Converts the decimal value (85) in hexa and stores it in a STRING ('55')
    bytearray[0] := ANY_TO_USINT(MyHexValue_0); // Converts the STRING in an USINT (55) so you can store it in the array
    28.11.2017
    18
    Quote Originally Posted by anthony.burille View Post
    Hi !
       bytearray[0] := ANY_TO_USINT(MyHexValue_0); // Converts the STRING in an USINT (55) so you can stores it in the array
    thanks that is what i want to do !
    28.11.2017
    18
    Quote Originally Posted by mos89 View Post
    Hi have an issue with negative number
    28.11.2017
    18
    not only negative numbers:
    myVarinHex_0 is a tmp variable in DINT
    08.12.2015
    39
    Aaaah... Yes, of course, I was focused on the '55' example, this was easy because converting a STRING to a DINT, it will not recognize this is an haxadecimal form, it processes the value by elimination, from the left to the right:
    STRING | DINT
    '55'       | 55
    '5 6'      | 5
    '5E'       | 5
    '16#5E' | 16
    So "strictly" converting a STRING which contains other characters than numbers, into a DINT, this is not possible.
    And of course hexadecimal values are often containing 'A', 'B', 'C', 'D', 'E' and 'F'...
    Then, this is not possible to do it using the SERIALIZEIN/SERIALIZEOUT functions because these are using array of bytes.
    But... Why storing hexadecimal values?
    As I said in the first post, if you store 85 in decimal, or 16#55 or 2#01010101, the value will be the same, it still is 85.
    If you strictly want to store the hexadecimal form of a value, then you have to store it in an array of STRING
    26.02.2021
    30
    Is this what you would do if you have to translate the value of a dint to individual bits values? Is there a way to do it without Logic? just with the Zenon local functions/elements/variable configuration?
    1,023
    @mst: please do not advise people to use a solution with simulator driver: it potentially results in licensing issues and it anyway not transfers the timestamp of variable value.
  1. Convert variable for Process Gateway
    By diemon in forum Drivers
    Last Post: 22nd June 2021, 15:48
  2. Styles content is not visible in Zenon 7.60
    By rahulindore05 in forum zenon Service Engine Supervisor
    Last Post: 12th May 2018, 08:14
  3. Comma as separator for decimal value
    By altera in forum zenon Service Engine Supervisor
    Last Post: 23rd August 2016, 10:17
  4. Dynamic limit texts with hexadecimal value
    By lew in forum zenon Service Engine Supervisor
    Last Post: 9th January 2012, 00:41
  5. convert anything to bit
    By brandt in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 7th February 2008, 13:04
