Showing results 1 to 10 of 13
Thread: how to convert the content of a variable in decimal into an hexadecimal value
    28.11.2017
    19
    Default how to convert the content of a variable in decimal into an hexadecimal value
    hi
    i would like to know how to to convert the content of a variable in decimal into an hexadecimal value
    08.12.2015
    39
    Default Re: how to convert the content of a variable in decimal into an hexadecimal value
    The value of a variable is always the same, in decimal, binary, hexadecimal... But you can view the hexadecimal form of a value, in debug (so while you are online or in simulation) doing a right-click on it > Hexadecimal display.
    If you want to recover the hexadecimal value of a variable in a STRING you can use the "HTOA" block.
    I hope it helps,
    Anthony
    28.11.2017
    19
    hi anthony
    i try to format a value from a DINT into an 8 bytes array
    1 bytearray[0]= 16#55 ascci code of 'U'
    2 bytearray[1]= 16#49 ascci code of 'I'
    3 bytearray[2] and  bytearray[3]= 16#01 index in hexa of my destination array
     bytearray[4]  bytearray[5] bytearray[6]  bytearray[7] value in hexa of my parameter
    so i am doing a serialize out to fill my value array but the user input the value in decimal i want to write it in the array in hexa
    08.12.2015
    39
    Hi !
    Mmmh... You mean, for example, the user is writing "85" (decimal value of 16#55) but you do not want to write "85" in your array of BYTEs, you want to have "55" (because it's the hexadecimal value), right?
    Then I think you can use the HTOA block this way:
    MyHexValue_0 := HTOA(DecimalUserValue_0); // Converts the decimal value (85) in hexa and stores it in a STRING ('55')
    bytearray[0] := ANY_TO_USINT(MyHexValue_0); // Converts the STRING in an USINT (55) so you can store it in the array
    28.11.2017
    19
    Quote Originally Posted by anthony.burille View Post
    Hi !
       bytearray[0] := ANY_TO_USINT(MyHexValue_0); // Converts the STRING in an USINT (55) so you can stores it in the array
    thanks that is what i want to do !
    28.11.2017
    19
    Quote Originally Posted by mos89 View Post
    Hi have an issue with negative number
  1. Convert variable for Process Gateway
    By diemon in forum Drivers
    Last Post: 30th October 2021, 08:01
  2. Styles content is not visible in Zenon 7.60
    By rahulindore05 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 12th May 2018, 08:14
  3. Comma as separator for decimal value
    By altera in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 23rd August 2016, 10:17
  4. Dynamic limit texts with hexadecimal value
    By lew in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 9th January 2012, 00:41
  5. convert anything to bit
    By brandt in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 7th February 2008, 13:04
