Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 13
Thread: how to convert the content of a variable in decimal into an hexadecimal value
    28.11.2017
    17
    Default how to convert the content of a variable in decimal into an hexadecimal value
    hi
    i would like to know how to to convert the content of a variable in decimal into an hexadecimal value
    08.12.2015
    39
    Default Re: how to convert the content of a variable in decimal into an hexadecimal value
    The value of a variable is always the same, in decimal, binary, hexadecimal... But you can view the hexadecimal form of a value, in debug (so while you are online or in simulation) doing a right-click on it > Hexadecimal display.
    If you want to recover the hexadecimal value of a variable in a STRING you can use the "HTOA" block.
    I hope it helps,
    Anthony
    28.11.2017
    17
    hi anthony
    i try to format a value from a DINT into an 8 bytes array
    1 bytearray[0]= 16#55 ascci code of 'U'
    2 bytearray[1]= 16#49 ascci code of 'I'
    3 bytearray[2] and  bytearray[3]= 16#01 index in hexa of my destination array
     bytearray[4]  bytearray[5] bytearray[6]  bytearray[7] value in hexa of my parameter
    so i am doing a serialize out to fill my value array but the user input the value in decimal i want to write it in the array in hexa
    08.12.2015
    39
    Hi !
    Mmmh... You mean, for example, the user is writing "85" (decimal value of 16#55) but you do not want to write "85" in your array of BYTEs, you want to have "55" (because it's the hexadecimal value), right?
    Then I think you can use the HTOA block this way:
    MyHexValue_0 := HTOA(DecimalUserValue_0); // Converts the decimal value (85) in hexa and stores it in a STRING ('55')
    bytearray[0] := ANY_TO_USINT(MyHexValue_0); // Converts the STRING in an USINT (55) so you can store it in the array
    28.11.2017
    17
    Quote Originally Posted by anthony.burille View Post
    Hi !
       bytearray[0] := ANY_TO_USINT(MyHexValue_0); // Converts the STRING in an USINT (55) so you can stores it in the array
    thanks that is what i want to do !
    28.11.2017
    17
    Quote Originally Posted by mos89 View Post
    Hi have an issue with negative number
    28.11.2017
    17
    not only negative numbers:
    myVarinHex_0 is a tmp variable in DINT
    08.12.2015
    39
    Aaaah... Yes, of course, I was focused on the '55' example, this was easy because converting a STRING to a DINT, it will not recognize this is an haxadecimal form, it processes the value by elimination, from the left to the right:
    STRING | DINT
    '55'       | 55
    '5 6'      | 5
    '5E'       | 5
    '16#5E' | 16
    So "strictly" converting a STRING which contains other characters than numbers, into a DINT, this is not possible.
    And of course hexadecimal values are often containing 'A', 'B', 'C', 'D', 'E' and 'F'...
    Then, this is not possible to do it using the SERIALIZEIN/SERIALIZEOUT functions because these are using array of bytes.
    But... Why storing hexadecimal values?
    As I said in the first post, if you store 85 in decimal, or 16#55 or 2#01010101, the value will be the same, it still is 85.
    If you strictly want to store the hexadecimal form of a value, then you have to store it in an array of STRING
  9. #9
    26.02.2021
    16
    Is this what you would do if you have to translate the value of a dint to individual bits values? Is there a way to do it without Logic? just with the Zenon local functions/elements/variable configuration?
  10. #10
    971
    @mst: please do not advise people to use a solution with simulator driver: it potentially results in licensing issues and it anyway not transfers the timestamp of variable value.
  1. Styles content is not visible in Zenon 7.60
    By rahulindore05 in forum zenon Service Engine Supervisor
    Last Post: 12th May 2018, 08:14
  2. Comma as separator for decimal value
    By altera in forum zenon Service Engine Supervisor
    Last Post: 23rd August 2016, 10:17
  3. Convert variable for Process Gateway
    By diemon in forum Drivers
    Last Post: 3rd March 2015, 09:07
  4. Dynamic limit texts with hexadecimal value
    By lew in forum zenon Service Engine Supervisor
    Last Post: 9th January 2012, 00:41
  5. convert anything to bit
    By brandt in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 7th February 2008, 13:04
