Thread: Reg: DPC Testing with varibale daignosis
    29.04.2014
    28
    Default Reg: DPC Testing with varibale daignosis
    Hi Team,
    Thanks to all your support in forum.
    I have a iec850 device which has double point. How can i test in varibale diagnosis.
    Simply adding variables will work or Do I have to create anything to test.
    Regards
    Sarav
    1,039
    Default Re: Reg: DPC Testing with varibale daignosis
    What do you want to test about this "double point"? Its current value?
    Yes, in screen 'Variable Diagnosis' you can see value of any variable, from any driver, of any data type or value ranges.
    To use Variable Diagnosis:
    - the screen must contain control elements. In Editor, you can easy create elements from a template.
    - the variable must be on the screen's list. In Editor, you can add this variable to the list in zenon 'screen switch' function opening this screen. In the Runtime - via screen's control button 'Add...'
    - the 'Variable Diagnosis' screen, per default, is not refreshing the list (no values/old values in the list). To acquire current variable values you have to: in Editor, in the function, activate the check-box 'refresh actual values on'. Or - in the Runtime - you may force update of the list via buttons 'refresh on' or 'refresh now'.
    Your question is nothing specific for Energy; the Variable Diagnosis is a common feature available with any zenon version a/o edition. To get fast answers about common features better post in threads about Supervisor.
  1. Command REG-DA OLTC with IEC61850
    By sstoilov@gmail.com in forum zenon Energy Edition
    Last Post: 14th March 2018, 11:41
  2. Testing a redundancy set up
    By SteveM in forum zenon Network
    Last Post: 10th May 2016, 14:40
  3. REG-DA (IEC 61850) in Zenon 7
    By bnekooie in forum zenon Energy Edition
    Last Post: 19th January 2016, 14:47
  4. REG-DA (IEC 61850) in Zenon 7
    By bnekooie in forum Drivers
  5. Command REG-DA OLTC with IEC61850
    By sstoilov@gmail.com in forum Drivers
    Last Post: 16th May 2012, 11:37
