Thread: Error while runtime creation about variables which doesn't exists in database. Help is required to solve this error
    29.04.2014
    27
    Default Error while runtime creation about variables which doesn't exists in database. Help is required to solve this error
    Dear Team,
                      Error while runtime creation about variables which doesn't exists in database. Help is required to solve this error.
    08.12.2015
    39
    Default Re: Error while runtime creation about variables which doesn't exists in database. Help is required to solve this error
    This kind of error must not happen in zenon.
    Unfortunately... As you can see there still are exceptions.
    I'm not sure someone from COPA-DATA can be able to help you on the forum, this is a very specific error for which we must be sure about:
      - How did this happen?
      - Is it reproductible?
      - Which version of zenon are you using?
      - If you try this and this, does this solve the problem?
    Sulutions exist for this kind of error, but these cannot be described on the forum as these must be used wisely and only exceptionally (again, depending on how you managed to get in this situation)
    I suggest you to contact your local COPA-DATA support so they will be able to guide you to solve this specific issue, with the appropriate assistance and tools,
    Anthony
    29.04.2014
    27
    Thanks Antony for the support, we will contact local support
  1. Database cannot be opened! Error
    By jhines in forum zenon Supervisor
    Last Post: 22nd February 2018, 01:14
  2. Doesn`t export error list
    By marcelodias in forum zenon Supervisor
    Last Post: 22nd March 2017, 14:11
  3. Re: Database cannot be opened! Error
    By jobertraj in forum zenon Supervisor
    Last Post: 27th October 2014, 08:16
  4. Import / Automatic creation of Variables in STRATON
    By prasadkh in forum straton / zenon Logic
    Last Post: 29th December 2009, 01:19
  5. Open database error
    By jan1024 in forum zenon Supervisor
    Last Post: 30th November 2009, 16:11
