Thread: Message control with MD720 modem
    31.10.2017
    5
    Default Message control with MD720 modem
    Hello; I have issues to communicate with siemens MD720 in order to user message control GSM modem, when a click check connection , I have message no connection could be established to the modem, at serial interface, on the diagnosis viewer error text is "the modem did not respond to at command" I already tested the modem with terminal by sending an SMS.
    I'm using sicam 230 v.700 win7 32.
    Did I miss any step.
    18.02.2014
    22
    Default Re: Message control with MD720 modem
    you can find a checklist for Message Control module on the COPA-DATA Homepage. You just have to Login with your user credentials. Go to tab "Support" --> "Knowledge Base / FAQ" --> Extended Search -->Select module Message Control and Checklist. See screenshot
  1. Message Control - Sprachnachricht mit GSM Modem versenden
    By ptkdennis in forum zenon Network
    Last Post: 2nd October 2015, 09:30
  2. Message control using USB GSM modem
    By a.oprean in forum zenon Network
    Last Post: 3rd September 2014, 02:15
  3. Message control using USB GSM modem
    By jessica in forum zenon Network
    Last Post: 24th June 2014, 07:20
  4. Message Control : Poll modem
    By crl_snef in forum zenon Network
    Last Post: 15th October 2013, 06:54
