Thread: Arrays with variable length
    04.04.2018
    Default Arrays with variable length
    I would like to know how to declare arrays with variable length in Zenon Logic?
    I need to create an UDFB with 2 data set from variable length.
    Objective would be to call twice the same FB with different dataSets
    Code:
    fbMyFunction(dataSet1);// Array from 5
    fbMyFunction(dataSet2);// Array from 10
    According to IEC-61131-3, it should be possible to declare arrays with variable length as following
    Code:
    arrMyArray   : ARRAY[*] OF LREAL;
    And then use functions LOWER_BOUND and UPPER_BOUND to find the limits from the array.
    Thanks for your help
    08.12.2015
    39
    Default Re: Arrays with variable length
    In zenon Logic, this is not possible to do this.
    But this could be an interesting feature, I will add it in our Functionality Suggestions list and ask if it could be implemented for the next releases.
    I wish you a nice weekend,
    Anthony
    05.12.2018
    Quote Originally Posted by anthony.burille View Post
    Anthony
    Good morning,
    can you give an update on the current status of this functionality?
    I am working on a use case where I have an input array of boolean variables of different length (in the range of 1 to 250) and I need to implement a simple OR which takes the array as input.
    Is this currently possible with zenon logic?
    All the best,
    Nikolas Rieble
    23.10.2018
    9
    Quote Originally Posted by Rieble View Post
    Good morning,
    All the best,
    Nikolas Rieble
    Hello Nikolas,
    Sorry for the late reply…
    After investigating on this feature we finally decided that this will not be implemented. This is too complicated as the whole compiler must be rearranged.
    Anyway, with the help of straton Development Kit, this is possible to create your own C blocks and to make it possible.
    Anthony
  1. The length of time column
    By parisamoosavi in forum zenon Supervisor
    Last Post: 27th October 2014, 14:27
  2. String length field for STRING variables.
    Last Post: 11th January 2013, 07:49
  3. Tooltip length is too short
    Last Post: 9th March 2012, 01:03
  4. Replies: 1
    Last Post: 2nd August 2011, 10:21
  5. Replies: 1
    Last Post: 23rd July 2011, 08:51
