Thread: Multiple binary inputstest to analogue value
    17.03.2016
    41
    Default Multiple binary inputs to analogue value
    Can anyone give some thoughts on the best way to take multiple single binary inputs and convert them to an analogue value?
    We have a tap changer which gives us discrete binary output for each tap position (eg 1 to 10). I'm looking to display this onscreen as a numberical value. What is the most efficent way to program this? I could create a combined element and use formula there is to display seperate images with a number in it for each input, but I'm thinking there may be a better way to do this (perhaps use a formula to convert to an analogue value whcih can then be displayed easily on screen). IS there a way I can combine multiple binaries together to create a single value (and can then use reaction matrix 'bits'?
    Thanks.
    810
    Default Re: Multiple binary inputstest to analogue value
    I would make a solution using zenon Logic.
    You may create a Logic project (to run on network servers) and use the values of these binary inputs to calculate the value of additional, integer variable - of stratonNG driver.
    Steps:
    1. create a Logic project, configure the binary input variables 'externally visible', in Logic create fieldbus driver 'Logic to SCADA connection'; cycle > 100ms
    2. create variable in stratonNG, e.g. "tap_position"
    3. ST-language code to calculate value:
    tap_position.0 := variable_binary_input1;
    tap_position.1 := variable_binary_input2;
    17.03.2016
    41
    Ursula,
    Thanks for the reply.. I will certainly give that a try, although I was hoping there would be way to do this without using Zenon Logic... in the editor only. Is there at least a way within Logic where I can create a 'template' logic and have it apply to all variables with a specifc naming convertion (eg ending _TAP01, TAP02 etc)?
    Cheers.
    08.12.2015
    39
    You could do this using a sub-program.
    In zenon Logic, right-click in your project-list > Insert new program > Choose a name, the programming language can be ST, and think to check Execution-style = Sub-program
    As inputs, your binary values. As an output, the values converted to an analog one.
    Then in the sub-program, as Ursula said:
       tap_pos.0 := bi_1;
       tap_pos.1 := bi_2;
    Finally in your main program you just have to use your sub-program multiple times.
       tap_position_TAP01 := My_SP( variable_binary_input1, variable_binary_input2, variable_binary_input3, ...);
       tap_position_TAP02 := My_SP( variable_binary_input10, variable_binary_input11, variable_binary_input12, ...);
    Cheers,
    Anthony
  1. Multiple monitors
    By prasadkh in forum zenon Supervisor
    Last Post: 21st June 2018, 08:00
  2. Analogue Output Command Processing
    By LeeCapula in forum zenon Energy Edition
    Last Post: 28th March 2018, 15:33
  3. Multiple variables
    By DavidMarek in forum straton / zenon Logic
    Last Post: 11th April 2016, 08:02
  4. binary Reaction matrix GI status bit
    By fgenc in forum zenon Supervisor
    Last Post: 11th October 2014, 23:38
  5. How can I produce event for Binary Output in all executions?
    Last Post: 26th November 2009, 10:20
