Thread: Dynamic text and special characters
    04.01.2018
    2
    Frage Dynamic text and special characters
    I'm currently trying to make it possible to enter ones email in a dynamic text variable in the runtime, but no matter what settings I try out, the "@" character is invisible.
    I am aware that writing two "@" characters beside one another fixes this, but that's not really intuitive for end-users.
    Is there some way of disabling this character as a prefix for these specific strings in Runtime version 7.6?
    15.11.2016
    106
    Default Re: Dynamic text and special characters
    Hello Jabbl,
    There is a setting in the project called "Display not translated keywords".
    You can find it in: Project -> Graphical design
    This will display the @ in cases where no translatable keyword was found.
    BR,
    Georg
    02.05.2017
    31
    Beitrag Re: Dynamic text and special characters
    Hello Jabbl,
    an alternative to Georg's solution is to directly deactivate the checkbox 'Translate display text' under the property node 'Text' of the dynamic text field. This has the following advantages:
    - Only applies this rule to the specified email field
    - Doesn't translate text if the suffix of the users email address happens to be in your translation list (although very unlikely that will ever be the case)
    - Doesn't show all untranslated keywords with an @ in front
    Which solution is better depends on your use case.
    Lukas
  1. Dynamic limit text in Dynamic Text element
    By sdolnyy in forum zenon Supervisor
    Last Post: 22nd July 2016, 12:57
  2. PDIAG alarms with dynamic text
    By leszkoo in forum Drivers
    Last Post: 29th February 2016, 08:03
  3. How to size a Dynamic Text Box
    By pilzfrance in forum zenon Supervisor
    Last Post: 10th March 2014, 02:26
  4. Dynamic text on momentary switch button
    Last Post: 8th May 2013, 08:30
  5. Why Dynamic Limit Text allows only 1 variable?
    By batabaha in forum zenon Supervisor
    Last Post: 1st May 2012, 23:51
