Thread: Zenon Runtime error
    Default Zenon Runtime error
    I am using IEC850 driver in Zenon 7.11 to communicate with a SEL IED. After starting the Runtime it is always reported a message
    "zenNetSrv.exe: Module could not be loaded! (Last error 0x00000000) ". Once I uncheck "Network Active" option then its working fine. Please help.....
    I have
    One server & one client PC with windows 7-64bit.
    Zenon-7.11.
    930
    Default Re: Zenon Runtime error
    In zenon Network, the communication from zenon runtime Client to zenon runtime Server occurs with the additional process started automatically with the runtime - called zenNetSrv. The zenNetSrv by default communicates over TCP Port 1100. Make sure that this port is not blocked on any firewalls.
    All port are enabled/allowed.
    15.11.2016
    107
    Please try to register through the "standard" button in the startup tool and see if that resolves the issue.
    Note:
    If the network is deactivated, the ZenNetSrv.exe is not started (not needed).
    BR,
    Georg
    930
    In your Firewall, the quantity of entries with the same zenon version - 7.11.0 - is strange. On my PC i have only an entry pro a zenon version and separated build installation. Are you sure at least one installation completed really successfully? As i see on your screenshot you have there also a 7.50 installation. So - as georgk proposed - before you start the Runtime make sure the right version is registered in Windows.
    Thank you for your reply.  Previously there is Zenon 7.50 was installed, but due to CCR compatibility & customer request We uninstalled 7.50 & installed Zenon 7.11.  Even 7.50 uninstalled completely & 7.11 installed successfully. I believe some files of 7.50 version are still available in the system for this error.  Can you elaborate the process to remove 7.50 version files completely & then I can installed fresh 7.11.
    Quote Originally Posted by georgk View Post
    Note:
    BR,
    Georg
    Dear Support,  I tried the same, But still issue is persisting.
  1. Zenon CE Runtime error
    By yzhyff in forum zenon Operator
    Last Post: 17th December 2014, 19:22
  2. zenon 7 Microsoft Visual C++ Runtime Library Error
    By alin.stoicovici in forum Editor and Runtime Setup
    Last Post: 20th November 2012, 09:29
  3. Replies: 1
    Last Post: 28th April 2011, 23:37
  4. Runtime Error
    By shikra in forum zenon Energy Edition
    Last Post: 10th April 2011, 16:25
    Last Post: 23rd March 2010, 04:16
