Showing results 1 to 10 of 10
Thread: Out of memory while starting editor
    02.02.2018
    8
    Default Out of memory while starting editor
    Hello ,
    While I am starting the zenon editor 64 bit at that time the "OUT OF MEMORY" popup window will open continuously .
    And zenon editor shows "stopped working"
    What is the exact issue?
    I'm using zenon 7.50
    Looking forward for reply.
    Thanks in advance.
    SRI
    15.11.2016
    99
    Default Re: Out of memory while starting editor
    The Windows Defender in Windows 10 can cause this.
    Make sure to include zenon in the exception rules of the Windows Defender.
    -C:\Program Files (x86)\COPA-DATA
    -C:\Program Files\COPA-DATA
    Hope that helps.
    BR,
    Georg
    02.02.2018
    8
    Quote Originally Posted by georgk View Post
    Hope that helps.
    BR,
    Georg
    Hello sir,
    Thanks for your quick reply,
    As per your comments I checked the windows defender and added the folder path in exclusion but still it is not working.
    Same error is coming. Looking forward to you.
    SRI
    02.07.2014
    27
    Hello SRI,
    Which specification has the PC where you are trying to start Editor?
    BR,
    stani
    02.02.2018
    8
    Quote Originally Posted by stani View Post
    Hello SRI,
    BR,
    stani
    Hello sir,
    The PC is windows 10 pro 64 bit and using zenon 7.50 in that. From startup tool I'm trying to open editor by pressing on 64 bit.
    SRI
    02.07.2014
    27
    Hi again,
    i was actually interested in hardware specifications of the PC, how much of RAM that PC has?
    As well as do you have any project if you select zenon 7.50 in the startup tool , then "Properties...", there is section "Editor" and there you have a options "Workspace" and "Editor-Project" where you usually have selected project which is going to be loaded on editor start.
    Check screenshot
    02.02.2018
    8
    Hi again,
    Check screenshot
    Hello ,
    The specs are windows 10 , 8 gb ram and yes I already selected the all project details in properties.
    SRI
    02.07.2014
    27
    Hi again,
    could you remove selected project from the properties in Editor section of the Startup Tool, "Workspace" and "Editor-Project", just simply delete everything from those 2 properties and try to start editor without any project preselected.
    BR,
    stani
    02.02.2018
    8
    Hi again,
    BR,
    stani
    Hello again,
    As per your comment I checked by removing properties from Startup Tool, "Workspace" and "Editor-Project", but at this time "Zenon has stopped working" this type of massage is coming.
    SRI
    14.05.2013
    Dear Sir,
    I am facing the same issue of Out of memory while starting the zenon editor.
    I have installed zenon 7.50 supervisor version on my Laptop having configuration(Windows 10 pro 64-bit OS).
    Also as per Copadata support, i have installed the build file (Zenon 750 build 36520). Still the error persists and zenon editor is getting stopped.
    Also i want to highlight that i have already started making project in it as it opened earlier. Suddenly on third day of installation the error appeared and zenon is stopped. I have taken the backup of prepared program by starting editor in 32-bit OS. It is working fine in 32-bit OS.
    Kindly support.
    regards,
    Sumit Biyani
  1. Starting runtime failed
    By steven.costantini in forum zenon Operator
    Last Post: 13th April 2016, 06:54
  2. Free memory (%) variable - for what kind of memory?
    Last Post: 4th June 2013, 15:26
  3. InitInstance():Out of memory
    Last Post: 4th April 2012, 23:58
  4. Replies: 0
    Last Post: 7th August 2008, 11:57
  5. memory on windows CE
    Last Post: 19th September 2007, 08:05
