Thread: ABB 3S_V3 Connection Problem
    Default ABB 3S_V3 Connection Problem
    hi everybody,
    i'm using ABB ZENON 7.6 and I have problem with the communication to the PLC in the driver:
    if there is 2 PLC's in the driver and they are connected O.K then everything is working good, but when there is 8 PLC's in the driver that only 2 of them are connected O.K and the rest of them are not connected, the connection between the zenon to the PLC's that connected takes a lots of time to establish or not working at all.
    i set the timeout in every PLC in the driver to 2000ms and 1 reties.
    Default Re: ABB 3S_V3 Connection Problem
    Usually zenon makes 3 times a try to connect to each device. Every try for connection to PLC needs approxiametly about 20 seconds. After this interval it jumps to the next device for connecting. If many devices are configured in the driver without connection, then These procedure could need a while. Also it depends on the used protocol, which I donīt know actually.
    If These 6 PLCīs are not needed for any reason, then it would make sense to Change the Connection mode from "Hardware" to "Simulation static". Or to create an additional Driver and put the rest of the PLCīs to the second Driver.
  1. I want to know how can i read the values from ABB M2M ?
    By babyoxhead in forum zenon Network
    Last Post: 23rd October 2014, 15:46
  2. Problem with remote connection to Analyzer SQL Server
    By altera in forum zenon Analyzer
    Last Post: 8th July 2014, 16:07
  3. WebServer connection
    By abcd1234 in forum Webserver/Webclient
    Last Post: 15th January 2014, 15:57
  4. SICAM 230 with ABB RTU560CMG
    By onder89 in forum zenon Energy Edition
    Last Post: 19th June 2013, 01:20
  5. Problem with OPC Connection
    By mastr in forum Drivers
    Last Post: 20th August 2008, 14:14
