Thread: web server zenon config location
    17.09.2017
    24
    Default web server zenon config location
    hi im using ABB zenon 7.6, im trying to use the web server and client but the problem is that the file "zenon" that contains the file config that Should be in C:\inetpub\wwwroot
    is located in C:\Program Files (x86)\ABB\zenon Web Server instead.
    so when i write "http://my_runtime/zenon/index.htm it can't find it.
    is copying the folder is ok? or it will have problem withe other files after?
    thank you
    15.11.2016
    99
    Default Re: web server zenon config location
    To use the WebServer you need to activate the Publishing service (IIS).
    If you install the WebServer before activating the IIS, the Folder will be placed in the mentioned path.
    See Information in the Help file:
    Manual -> zenon Web Server -> zenon Web Server, Web Server Pro and Web Server Pro Light -> Required components and their definitions -> Publishing service installation
    Info
    If the zenon Web Server was already installed before the publishing service, or if a different publishing service is used, the folder created during installation of the zenon Web Server
    C:\Program Files (x86) \ABB\zenonWebserver\zenon must be moved manually to C:\inetpub\wwwroot or to the root folder of the alternative publishing service.
    So activate the publishing service as mentioned in the help and then move the folder.
    You can open the help by pressing F1 in the Editor, or via the Startup-Tool.
    Hope that helps.
    BR,
    Georg
  1. Zenon Web Client and Terminal Server 2012
    By luca.bardon in forum Webserver/Webclient
    Last Post: 14th April 2016, 15:46
  2. zenon Web-Client 7 -> Web-Server 6.22 slow startup
  3. Problem with Web Server on zenOn 7.10
    By misbah in forum Webserver/Webclient
    Last Post: 26th August 2013, 05:42
  4. ZenOn Web Server and VBA?
    By nblanquart in forum Webserver/Webclient
    Last Post: 28th July 2010, 23:34
  5. We need further information about web server on zenOn...
    By nuno_duarte in forum zenon Network
    Last Post: 18th March 2008, 18:05
