Thread: error when installing zenon 7.6 operator
    17.09.2017
    24
    Default error when installing zenon 7.6 operator
    hi i'm installing zenon 7.6 on a project pc and everything is ok except the installation of the editor.
    log is attached.
    thank you
    11.06.2013
    32
    Default Re: error when installing zenon 7.6 operator
    Hi eden212!
    Thank you for your post.
    As far as I could see, you have issues with ABB zenon installation.
    May, you could get in contact with your responsible ABB-Support concerning this issue.
    Br
    17.09.2017
    24
    Thank you, I solved the problem.
  1. Zenon client in OWS (Operator Work Station) not running from Server
    By patangia.ramananda@gazpromneft-badra.com in forum zenon Network
    Last Post: 28th December 2015, 04:44
  2. Use of Zénon Operator ?
    By florian in forum zenon Operator
    Last Post: 9th June 2015, 12:51
  3. Installing zenOn on iPad
    By salmanhassan2 in forum Editor and Runtime Setup
    Last Post: 7th February 2013, 00:01
  4. error in installing zenon7 operator about the sql
    Last Post: 29th May 2012, 03:02
  5. Zenon 7.0 installing error
    By croc in forum Editor and Runtime Setup
    Last Post: 18th April 2012, 05:45
