Thread: Hardware Requirements
    30.03.2017
    32
    Default Hardware Requirements
    Hi support,
    We want change an exisiting SCADA to Zenon EE, but client wants use the existing computers (hot stand by system). The computers are:
    - Model: UNO4683
      Manufacter: Advantech
      W7 PRO
      Core i7 2.0 GHz
      4G DDR3 SDRAM
      64GB SSD
    - Model: ECU4784
      W8 or W10
      Intel Haswell Core i7 4650U 1.7GHz dual-core
      DDR3L 1.35V non-ECC 8G
      128GB SSD
    The architecture is a redudnacy system (with a monitor, keyboard and mouse connected to both server with a kvm), SCADA talks with 20 IEDs in IEC61850, 3 IEDs in Modbus and send dato to a Master SCADA in IEC104 and Modbus to another.
    Will be a problem to use the same computers?
    Thanks in advance for your support.
    Josť Luis Torres
    15.06.2017
    4
    Default Re: Hardware Requirements
    Hi Jose,
    You should look in the help documentation located under for more specific information:
    Manual -> Installation and updates -> System requirements -> Hardware requirements
    Personally, I do not see any issues with the hardware you listed. Everything else you mentioned can be handled in zenon (redundancy, IEC61850, Modbus...).
  1. Hardware Requirements (General)
    Last Post: 15th January 2015, 20:09
  2. Send Value to hardware
    By anahita in forum VBA
    Last Post: 7th August 2011, 22:54
  3. what is the minimum system requirements of your ZenOn products?
    By lephis in forum Editor and Runtime Setup
    Last Post: 8th February 2010, 08:27
  4. Send To Hardware in 6.22
    By madphilly in forum VBA
    Last Post: 22nd September 2008, 15:06
  5. send value to hardware
    By dak2483 in forum Drivers
    Last Post: 19th September 2008, 16:33
